Toshiba microwave oven, purchased in Australia around 1984. The white cover in the ceiling of the oven, (covering what maybe the source of the waves?) has become dislodged and fallen off. There are three screw holes in the cover, but the screws are nowhere to be found. Can I replace with ordinary screws? Can I use the oven without the cover? Where can I find help to fix such an old machine in Surrey?
There are nylon push-in fasteners that snap into place. If there is a shop that works on microwaves, they will generally have them. Over time these fasteners get brittle and crumble away. Another option is to use nylon screws, if you can find some the right size. I don't recommend metal screws as they may arc in the cooking cavity. Using the microwave without the cover will result in spattered food getting into areas that can't be cleaned.
It sounds like what you are talking about is an issue with the waveguide cover. It is usually made
of a material called Mica. Its purpose is to cover the aperture through which
the microwaves enter the oven cavity from where they are produced by the
Magnetron behind the control panel. It stops moisture and food particles
getting into the "workings" of the microwave.
if your microwave is working ok and behaving itself
then there is nothing to worry about, but there may be one of 3 problems that
may arise which should be rectified.
1. Its fallen off.
2. It has a hole in it.
3. It is arcing or sparking during use.
In any eventuality it should be replaced. If it has
fallen off or got a hole in it then there is the risk of food or moisture
getting into the waveguide which will reduce the efficiency of the oven. If it
is arcing or sparking then continued use will damage other components in the
microwave including the oven cavity which could be costly to rectify.
If there are any issues with
your waveguide cover it should be replaced. When new the mica sheet is rigid
and firm. Over a period of time it absorbs moisture and gets food splatters on
it. It then becomes soft and flexible. The cover can be replaced either with a
suitable replacement made by the manufacturer of the microwave or if the old
cover is in good enough shape to be used as a template, blank sheets of mica
can be purchased and cut to fit.
