I have an older Niokia phone and there is a flashing message icon
The charge on my phone went out and after I plugged it in there is a flashing message icon in the top left hand corner. How do I retrieve the message as it doesn't show anything new in the inbox? Thank you.
Re: I have an older Niokia phone and there is a flashing...
It may be a voicmail, or if after you restart the phone, if the messages do not show up, take it to your local phone retailer and they should be able to help replace the unit
i had that same exact problem, with my razr so i just went out and bought a new battery for like 15 dollars, and now it works like a charm thanks........
Your battery is dead and will no longer hold a charge. If it is a newer computer, then it may be defective and covered under your warranty. If it is an older computer, this is the unfortunate thing about rechargeable batteries...eventually they will no longer hold a charge.
i cant figured out the battery issue myself but you can reset the voice icon to zero through setting ...more...morephone settings then more again then hit the clear voicemail icon
i have noticed that the mini plug for the charger and usb connection on RAZR V3 is sometimes sloppy. when the phone is charging it will definitely say battery charging on the external display and also flash the battery icon. i also noticed that the plug for the wall outlet is touchy. make sure the plug is secure in the wall outlet make sure the mini plug is secure in the phone gently wiggle these connections if you have to till you get the battery charging message if there are any connection problems there will be a unable to charge message instead.
