You should disable the hibernation feature. It is utterly useless.
Using Windows XP, RIGHT click anywhere on the desktop and then select PROPERTIES.
From there, select the SCREEN SAVER tab.
In the section, "MONITOR POWER" click on the POWER button.
Go to the HIBERNATE tab.
UNCHECK the box for ENABLE HIBERNATION.
Click on OK, etc. and close out the display properties tab.
For safety's sake, restart your PC and see how things work out for you.
Blessings!
Many thanks for your speedy help.I did as you suggested and unfortunately it was not the cure. So I tried turning the screen off manually and then a couple of hours later upon return I switched the screen back on again only to find the same problem happened.
