Dish washer wont clean properly. I have removed the spray arms and cleaned both the top and bottom arms. I have also checked the drainage pum is also not blocked. Water does appear to enter the dishwasher but not sufficiently enough to move the spray arms. I have a NEFF dishwasher.
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
