KitchenAid 24 in. KUDS02SR Built-in Dishwasher Logo
Posted on Feb 23, 2010
2-year old unit. Cleaning quality has become
2-year old unit. Cleaning quality has become increasingly poor over the past few months. Each load will have a dish or bowl (or several) which come out almost as dirty as they went in - even with prerinsing. Please let me know if there's anything I can do to fix this. Thanks.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Feb 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
5802
Points
18
Clean your machine using White Vinegar
You can remove your spray arms and soak them in Vinegar to unblock them blowing out rubbish and unblock the small holes
What causes boor print quality?
It sounds like the print head might need cleaning, but that's a guess. Does the manual include any information on cleaning the head?
Lg ldf7932ss growling noise at wash cycle
The LG is known for the main motor bearings (2 small cheap) bearings that are of poor quality and become noisy (growls) after a period of time. I pulled the motor and replaced the Korean bearings with quality German equivalents. This is cheap and solves the problem. (the front bearing closest to the plastic pump is the culprit.
My monitor will is all grainy I have connected it to a Sony Vaio (4 months old) downloaded latest drivers etc but still [poor quality -
I think it is your screen resolution it needs to be increased, go through my published guide entitled How to set your Desktop Screen Resolution?
Increased resolution and colour quality will give you an excellent picture.
damnor01
1helpful
I have a SubZero 690, approx 11 years old. It has tripped the circuit breaker twice, approximately 5 month apart. No additional load on the 20 amp breaker at the time. Can you suggest if it is the unit,...
Good day,
5 months surely doesn't point to the machine. I would check the wiring and replace the breaker and retest.
Breakers can become weak from age. They are by definition a heat operated device. Due to just happenstance it is posssible for both compressors to try to start at exactly the same time.
That would push the demand fairly high.
As well, usually unknown, breakers are rated at 80% of their value for continious duty. I.E. 20 amp breaker can maintain a load of 16 amps under continious load.
One caveat. The condenser coils need to be cleaned on an annual basis. To vacuum them is a poor solution. They need to be blown out with compressed air or a quality shop vac. Ugly but extremely important on Sub Zero's.
3helpful
Craftsman 16'' 36cc's oil to fuel mixture, and bar oil requirements
Your Craftsman is probably a Poulan, for the past few years Poulan has recommended a 40:1 ratio 1 gal premium/3.2 oz quality 2-cycle engine oil. I'd thin down even a little more 50:1 (1 gal premium/2.6 oz quality 2-cycle engine
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine.
For the bar every home center and hardware sells bar oil. It is 30 weight non-detergent oil with a few additives to help it adhere where lubrication is needed. HTH
Lou
Nov 16, 2009 • Garden
Sony KP-53V85
My unit is 9 years old, almost 10 (in 2 months) and started the same a couple of months ago. The only way to fix it is to have them serviced by a tech and replace the projectors. Its just the age/use of the unit catching up with it.
Many resellers sold them with an offer to sell you an optional maintence service where they would fix/clean/replace the projectors for upto 5 years after purchase. I'm not sure if they even have the parts anymore since these tv's are no longer produced. After market repairs are likely to cost as much as or nearly as much as buying a new flat screen tv.
Poor sound quality
This is just a guess but the dolby sound on my system is bad however when I switch to regular "stereo" sound it improves. See if your audio set up has a choice of sound and try them all.
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
