Question about HP Compaq Presario CQ50-110US Laptop
Will not turn on battery is good - HP Compaq Presario CQ50-110US Laptop
Posted by bwing1943 on
Anonymous
  • 916 Answers
Please test the power adapter with a multmeter and make sure it is working properly. If it is not it will not charge the battery and needs to be replaced.
Posted on Feb 23, 2010
Bike won't turn on after battery has been replaced
Hey, just because the battery sparks DOES NOT mean the battery is good...THE ONLY was to tell is to have the CCA (Cold Cranking Amps) checked..a battery company, Oreilly's, Autozone..etc.. can check it...
A battery can have 13+ volts and 0 CCA and IS BAD!!!!
Jul 24, 2017 | Honda VT 750 CD Shadow A.C.E. Deluxe...
2001 honda civic wont turn over, battery-starter-good, timing belt good, engine will turn by hand but when attempting to start it just clicks. Im leaning towards the ckp sensor
The crank sensor only comes into play while the engine is cranking or running to tell the computer where TDC is.
A no crank issue would be only the starting or security system.
Do you have battery power at the starter when the key is in the start position ? Are the battery cables clean and tight on both ends ?
Feb 04, 2014 | 2001 Honda Civic
Battiey good, but will not start or even turn over
LETS SEE BATTERY GOOD! STARTER GOOD? BATTERY CABLES GOOD? CONNECTION FROM THE BATTERY GOOD! CONNECTION FROM THE STARTER TO THE BATTERY GOOD!
WIRE FROM THE STARTER TO THE IGNITION SWITCH GOOD???
IN THIS WIRE THERE IS A FUSEABLE LINK CHECK IT
IF YOU CAN SHORT THE SOLINOID OUT ON THE STARTER AND THE CAR TURNS OVER THE FUSEABLE LINK IS BAD
IF EVERYTHING IS GOOD CHECK TO SEE IF THE MOTOR IS GOOD
Mar 02, 2010 | 1996 Jeep Cherokee Sport
Turn key will not start battery is good
Make sure the connections and the cables are good.No corrosion on cables.If the lights in the dash flicker this is usually a sign that the battery is not good or it is not making good contact.Have the charging system and battery load tested.Hope this helps.Good luck.
Dec 25, 2009 | 2002 Chrysler Concorde
Won't turn on...battery is good
You'll have to take your DS apart to make sure that the battery hasn't exploded. Even if the DS says the battery is good that's not always true.
If the battery appears to be good you might want to send in your DS for repair. If the battery seems to be broken you can buy a new one on Ebay or anywhere else on the internet.
Good luck,
Brandonmxb
Dec 12, 2009 | Nintendo DS Lite Console
05 Dodge Ram will not start or turn over even when being jumped off. Just clicks. Last night when I tried to start it, ALL THE INTERIOR LIGHTS STARTED FLASHING AS WELL AS THE INSTRUMENT PANEL.
SOUND LIKE BATTERY IS DEAD.CHECK BATTERY VOLTAGE.A GOOD BATTERY VOLTAGE IS 12.5 VOLTS.IF LOWER REPLACE BATTERY.IF BATTERY IS GOOD CHECK BATTERY CABLES FOR TIGHTNESS AND CORROSSION.IF CABLES CHECK OUT GOOD.I AM LOOKING AT STARTER SOLENOID.REMOVE HAVE IT CHECKED.REMIND YOU TURN OFF RADIO BEFORE REMOVING CABLES SO YOU WONT LOSE CODE TO PLAY RADIO.IF IT TURN OUT THE BATTERY IS BAD. HAVE ALTERNATOR OUT PUT CHECK TO MAKE SURE ITS CHARGING THE BATTERY.
Oct 04, 2009 | 2005 Dodge Ram 1500
Upon turning key loud clicking under hood, no turn over
The clicking you hear usually indicates a poor battery or battery connection. Have your battery load tested first. You may have a bad cell in it causing it to be weak enough not to be able to supply the amps needed to turn the starter. If you haven't had the battery load tested then it could be bad. My guess is that the battery is bad. Good luck.
Mar 09, 2009 | 1998 Ford Ranger SuperCab
2005 colorado battery good wont turn over
make sure vehicle is in park good move shift selector around and try again.. also battery has good connections right ? clean posts on battery sometimes this happens
Jan 25, 2009 | 2004 Chevrolet Colorado
Polaroid A700 digital camera
my batteries are good but the camera just wont turn on at all
Jan 30, 2008 | Polaroid a300 Digital Camera
HP Compaq Presario CQ50-110US Laptop Logo
110 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
