2 of the wires should be 110volts (power) and the other 3 wires will be function (signal).....Fan, Pump, Etc....Set timer for N/O terminal......Timer setting will close the N/O terminal and power the function.......Use Your meter to find 2 110volt wires for power terminals and go from there for timed function.....Electrical shock hazard exist, so be sure to turn off appropriate breaker while making terminations....
Machine will not turn on because the front door latch has a switch on it to close the circuit and power up the appliance when door is closed. If door is open switch does not close and unit will not function.
U need to find out the problem with the latching mechanism and either fix or replace it.
To turn this feature off. These 3 buttons need to be pressed and held down in this order. Press and hold the Function button then Press and hold Original Size (Ledger) then Press the 3 You ar now in the service mode. Press the #5 then start Scroll to #88 and select Turn off then press close Press and hold Funtion and Clear to exit service mode
I have a LG GW300 mobile phone.I can't take pictures on it anymore everytime I turn the Camera and video camera it shows the DSP Unavailable Close Module error.
you re-initialise the system by moving the window upwards and hold the button for four seconds. Then move down the window and hold the button for another four seconds. Turn ignition off , wait two seconds. Now the auto function should be operable.
