Brother SX-4000 Typewriter Logo
Posted on Feb 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I press the "correct" button, nothing erases. How do I fix this?
Dick O Reilly
Level 3:
  • Brother Master 3,594 Answers
  • Posted on Mar 03, 2010
Dick  O Reilly
Brother Master
Level 3:
Answers
3594
Questions
Helped
609534
Points
6852
If the T/W is going thru the lift off movements the correction tape may be installed with the wrong side towards the paper. Dull side towards the paper.
DickyO
Samsung smartphone manual
Press and hold the Home button and the Power button until you see the Samsung logo. With the Volume Up/Down buttons chose "wipe data/factory reset", select it with the Power button. Next "Yes -- erase........", and finaly "reset"
Garmin froze on erase
Try performing a soft and or hard reset on the GPS.
The soft reset is done with the unit disconnected from the power cord, press and hold the power button down for at least 10 seconds until the Garmin screen is displayed.
The hard reset is done with the unit disconnected from the power cord and the unit off, press and hold the lower right corner of the screen and press the power button. A prompt will appear asking "Do you really want to erase all user data?". This will erase all favorites that were saved to the unit. Press yes to reset the unit to factory specifications.
Run the Garmin WebUpdater program to install or reinstall the latest software for your device. This will usually fix any issues.
Be sure to download the correct version for PC or Mac.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
You may also want to contact Garmin Support for assistance.
1-800-800-1020
2helpful
2answers
I deleted my audio files directly from the computer. Now that I try to record again, the device says that memory is full, even though I have no files on it. How do I reset it to record again?
To erase a selected file, first press the [ERASE] button. Next, press the [+] (plus) or [-] (minus) button to select "ERASE," and then press the [ERASE] or [OK] button.
To erase all files in a folder, first select the folder and press the [ERASE] button for three seconds or longer. Next, press the [+] (plus) or [-] (minus) button to select "ALL ERASE." Finally, press the [ERASE] or [OK] button.
NOTE:
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended. Individual files can be deleted using the computer with no negative effects.
How do I erase on my vn 5200PC ? I have tried pressing the erase button and then pressing Ok. That does not work. I have tried pressing erase button twice and then pressing Ok. That does not work. The read...
if the problem persists you could plug it to the pc and open your device and manually deleting or formating the device, formatting the device will erase everything on it
6helpful
2answers
Just got the CD445 Base Station. Red light keeps blinking
press the cid button then press menu then scroll through your missed calls then hit exit
2answers
I cant erase anything off my Olymous VN 240 recorder!
I have the same unit that is not working at this time, but if I remember correctly try this: Once the "yes" comes up to erase, hit the erase button again. If that doesn't work, press in the center of the large round button. Hope this works for you, if not download instructions from website.
I LOST THE MANUAL. CAN'T FIGURE OUT HOW TO ERASE PERVIOUSLY RECORDINGS.
How are files erased from the VN-3100PC?
Individual selected files or the entire contents of a selected folder can be erased from the VN-3100PC.
To erase a selected file:
  1. Press the [REW]or [FF] button to select the file.
  2. Press the [ERASE] button.
  3. Press the [REW] or [FF] button to select YES.
  4. Press the [PLAY] button.
To erase the contents of a folder:
  1. Press the [REW] or [FF] button to select the folder.
  2. Press the [ERASE] button twice.
Erased files cannot be retrieved.
hope this helps! =]
thanks for using fix ya
Help dont want to lose everything
The reason it is asking you if you want to delete all is because you have not selected specific files to erase, so when you hit erase without selecting a file it assumes you mean delete all.
To erase try these steps...
To erase a selected file from Folder A, B, or C:
  1. Press the MENU/FOLDER button to select Folder A, B, or C.
  2. Press the - or + button to select the file to be erased.
  3. Press the ERASE button.
  4. Press the - or + button to select YES.
  5. Press the ENTER/INDEX button.
To erase the contents of Folder A, B, or C:
  2. Press the ERASE button twice.
  3. Press the - or + button to select YES.
  4. Press the ENTER/INDEX button.
To erase a selected file from a date subfolder in Folder S:
  1. Press the MENU/FOLDER button to select Folder S.
  2. Press the - or + button to select the date subfolder.
  3. Press the PLAY button.
  4. Press the - or + button to select the file to be erased.
  5. Press the STOP button.
  6. Press the ERASE button.Press the - or + button to select YES.
  7. Press the ENTER/INDEX button.
To erase the contents of a date subfolder in Folder S:
  2. Press the - or + button to select the date subfolder to be erased.
  3. Press the ERASE button twice.
To erase the contents of a month subfolder in Folder S:
  2. Press the ERASE button three times.
  3. Press the STOP or PLAY button to select the month subfolder to be erased.
  5. Press the - or + button to select YES.
  6. Press the ENTER/INDEX button.
To erase the contents of Folder S:
  2. Press the ERASE button four times.
I want to delete some files!
PS. here is a link to download manuals and software for this device:
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1080
Good Luck ... oh and dont forget to rate my response.
Norman Weimar
Norman Weimar
k24674
