Question about Dehumidifiers
HI my samsung split sytem aircon is dripping water on to my carpet? only just started today. Richard
Posted by rgordon7 on
Anonymous
    New Friend:
  • 66 Answers
Check outside for the drain hose and make sure water is draining.If not, disconnect hose at evaporator ,and blow it out. Do not **** it from the open end: it does not taste good.
Posted on Feb 23, 2010
Hi! My home dry 660 collects water but also has started leaking onto carpet? Is this a big fix? It is probably about 10years old!
not that big of a job ! it just needs a good cleaning out, start by unhooking power and then remove outer case , look inside at area that has lots of fins !! fine aluminum ones !! there should be a water tray just below the fins ! im betting this is well garb'd up with yuk!! take a 50/50 water bleach solution (gloves would be a good idea too) and work some f this around in the tray till it loosens up , remove with old towels or rags (throw em away) and find the drain hole in the tray that allows the water to drain into collection pan and poke down it with the end of a old pencil to clean it out as well (don't use metal) don't forget to clean your fan blades off too before reinstalling cover and leveling unit before reconnection power
Nov 17, 2016 | Dehumidifiers
I have a whirlpool dehumidifier it is on but will not absorb and water from my carpet
Interesting problem. By the time you read this your carpet is full of mold. You need to put a blower under the carpet to move air through it. The dehumidifier will then adsorbe water from the air if it is operating.
May 06, 2014 | Whirlpool AD50USS Dehumidifier
Unit is not collecting water and carpet is wet
Unplug it and let it dry out. Place it on old newspaper and start. Check the paper and look for the wet spot. That will let you know where the water is coming out of the unit. Check that area, it is probably a bad seal on the drain or a crack in the water container.
Feb 16, 2014 | Whirlpool AD50USL Dehumidifier
Delonghi troubleshooting
Hi, my friend gave me a delonghi 5 cup k mix coffee maker. the water starts to heat you a hear a gurgle a little water is filtered to the pot and then nothing it just stops working. any ideas on how to trouble shoot?
Jan 02, 2014 | Dehumidifiers
Tasciugo dehumidifer about 10 years old has started to leak. I have cleaned filter and spout water drips from is there anything else I should do. ?
Drips from where?
Find the source of the drip and seal it with rubber or waterproof tape.
If there is no pressure at the leak, this should cure it.
If you have trouble locating the leak, dry off everything and operate the
dehumidifier while you watch for the appearance of the moisture. Where
it first appears is probably the leaking location.
Aug 29, 2011 | DeLonghi Dehumidifiers
My Frigidaire dehumidifier no longer drips water into the bucket but drips oil. What happened?
You have a leak in the refrigeration system...that is why it is not cooling and condensing water and why it is dripping oil...
Here is a tip that I wrote to help people tofigure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 26, 2011 | Frigidaire FDR25S1 Dehumidifier
Hi, I have a Haier HD306 Dehumidifier. I'm having an issue of the water dripping onto the floor. There is no crack or leak coming from the bucket itself. The leak seems to be coming from the back...
When my unit did that, I found that it was because the drain tube was plugged with lint and/or dirt...
Run a large tooth pick or wire up inside the drain and see if the water doesn't start running right out of there...
heatman101
Jul 26, 2011 | Haier HD306 Dehumidifier
My dehumidfyer doesnt drip any water but it the motor works
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 02, 2011 | LG LHD45EL Dehumidifier
Problem
Is your pump hose connected tightly?
Jul 20, 2008 | DeLonghi DE500P Dehumidifier
Dehumidifiers Logo
Top Dehumidifiers Experts
Marvin
Marvin
STEVE SPAM REMOVER
ray gallant
Are you a Dehumidifier Expert? Answer questions, earn points and help others
