Question about Ruud Matching Split Air Conditioner
It making a humming sound and the fan is going around slow the temp in home is 74 the set temp is 65 so it should not be running what could be the problem ruud upka-035jak is model
Posted by underdogz75 on
Anonymous
    New Friend:
  • 66 Answers
If you are running A.C.,and the T-stat is set at 65,and the room temp is 74,the A.C. will run until the temp goes down to about 65 or so.Turn T-stat to 76 and the unit should shut down. Also,check furnace filter for dirt, and check condensor unit coils and see if they are dirty.If condensor coil is dirty it cannot breathe properly. That will cause the compressor, and the blower motor to overheat.Wash cond. coil down with water hose to clean .Start at top of coil and go sideways,slowly going down.
Posted on Feb 23, 2010
My thermostat show 74 degrees as a current room temp...but we have it set at 70 and it's probably 65 in the house. ..the only way it will turn on is if I put it 74 or 75????
The old white-rogers thermostats with a mercury switch are adjustable. snap the face off. In the center you will find a plastic slot screw. set the indicator to the actual room temp.
Other type ? Replace the thermostat
Mar 01, 2015 | Heating & Cooling
I have a White-Rodgers programmable thermostat. I have it set to go to 74 degrees at 11:00 PM. It has started going to 74 at between 10:00 and 10:30 PM. If I press run it goes back to the daytime temp...
Hello I assume its cooling program.Probally the thermostat has a recovery mode.In another words the thermostat will come on EARLY to make sure you are at (74*f at 11:00).Maybe try 11:30 start time and see if that helps or disable energy recovery mode.
Jun 17, 2011 | Heating & Cooling
Radiator fan run late up to 220f
WELL SOME OF THE OLDER CAR RUN A LITTLE HOTTER THAN NEWER CARS THE COOLANT FAN WOULD TURN ON AROUND 180 TO 190 DEGREES.THE OLDER CAR I REMEMBER THE OLDSMOBILE AND PONTIAC ENGINE RUN A LITTLE HOTTER BACK WHEN I OWN ONE.
Jun 13, 2010 | 1989 Pontiac Firebird
Ceiling fan runs slow on highest setting. Or not a all on lower settings. Motor hums so it is try ing to work.
Sounds like something is binding. If you have full voltage on the fan and you can't find the source of what is binding, you will have to replace it.
Apr 09, 2010 | 2003 Oldsmobile Silhouette
I set temp to 74 and stop at 70 and decresing.
Sounds like the variances are not set right. if I am understand you. You set the thermostat to 74 and the heater shuts off at 70? If that is correct then the variances are wrong or you have placed the T stat in a bad location where it is getting heat from a vent, wall where there is a appliance or in a very drafty location
Feb 10, 2009 | Hunter Fan Company 5/1/1 Programmable...
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Infocus in26 fan runs continually
The fan does run continuously on this projector however it should be running very very slow when the projector has completed it's lamp cool down routine.
The reason for this is that a portion of the switching power supply remains energized (running) when the projector is at rest. But as I mentioned it should run very slow in this state. If it remains running full blast then most likely the fan speed control chip is shorted which can cause fail 2 ways, either the fan 1. runs full
speed or 2. remains stalled (then the projector will go over-temp and shut itself down) I hope this answers you question.
Cheers
Dec 18, 2008 | InFocus IN26 Multimedia Projector
Ruud Matching Split Air Conditioner Logo
203 people viewed this question
Top Ruud Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Marvin
Marvin
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
