Question about Onkyo HTR500 Receiver
When i push power button clicks on immediately
When i push power button the receiver turns on.then immediately turns off
Posted by robie_jns on
Anarchy333
    New Friend:
I had this problem also and discovered an easy way to trick it into powering on: Click the power button, then within 1 second of the receiver powering off, click the power button again. The receiver should stay on this time. This works with both the button on the receiver and the remote control.
I would like to know what causes this problem and whether or not I should be concerned about damage being done. I assume this is a power protection. I haven't tried plugging this receiver into a different power socket to test, but I don't think the power plug is the problem. Note: I have the subwoofer plugged into the power plug on the back of the receiver.
Posted on Feb 27, 2010
Speaker A button turns on receiver - Not power button
With the unit on, try a reset. If there is a small hole in the back somewhere, gently poke a toothpick in about 1/4". You should feel a soft click. If there is no reset hole, disconnect the power cord for a day or 2. If that doesn't help, you'll have to take it in for repair.
Apr 06, 2014 | Denon AVR-1708 Receiver
The receiver will not turn on and there is an audible relay clicking on and off.
You have a problem with the power supply or audio amp section. Most likely shorted audio output transistors.
Apr 05, 2014 | Panasonic Sa-pt770 Receiver
After a power outage my denon 2803 receiver will not turn on.
Hello. First unplug and replug in your receivers. When you push the power button, you should hear 1 click. Within 5 seconds, you should hear a second click. Can you please tell me the results?
Thank you.
Sep 15, 2012 | Denon AVR-2803 Receiver
I have a yamaha htr-6130 receiver that won't power on. When I push the power button it makes a click noise like it used to when it turned on immediately followed by another click. No lights come or or...
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 29, 2011 | Yamaha HTR-6130 Receiver
Onkyo receiver always shuts off
power output shuts ......send to service
Oct 02, 2009 | Yamaha RX-V596 Receiver
Receiver makes clicking sound when I push power, but does not turn on.
Sounds like a fualty push button - try connecting/soldering on a new one of a different type!
Jul 04, 2008 | Audio Players & Recorders
Stand-by light on, but receiver won't power up
Power supply problem. Most equipment today has remotes and the power supply has to remain on to sense the remotes signal.
But the actual receiver section does not get power until the remote says so or you hit the power on button on the unit. Internally the supply then feeds the device. Most likely cause is a power surge or storm.
See if the remote will power it up?
I presume this is still under warranty. If you don't have it plugged into a good surge supression outlet strip, Get one!
Mister Phil
Apr 05, 2008 | Audio Players & Recorders
Onkyo HTR500 Receiver Logo
1,189 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
