Question about Pioneer SD-P5795W 57" Rear Projection Television
PIONEER SD-P5795W WONT TURN ON
I PUSH THE POWER BUTTON THE LIGHT IS RED.THEN IT CLICKS LIGHT TURNS GREEN THEN IT CLICKS AGAIN AND THE LIGHT TURNS RED. NO SOUND NO PICTURE. WHAT IS GOING ON
1 Related Answer
Anonymous
SOURCE: 55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Posted on Nov 08, 2008
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
Oct 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer Rear Projection TV problems
a 240 ac voltage appliance will run happily on 220 volts but ther is obviously a fault as the green spark was possibly a fuse blowing
ie main fuse as power is not reaching the tv
Aug 14, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
Sd-p55a3-k/kc this tv does not turn on
Th convergance amps have failed you will half to replace them, or have it done parts are around 70 dollars not and easy fix on a pioneer time consuming
Dec 10, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Power Supply part problem with a SD-P5795W
I wouldn't trust anything this repairman said reason well for one thing how could he (or anyone) tell everything else is "in perfect condition" when he couldn't "see" anything to tell what it looked like. He might be right about the power supply being bad But it could also be the high voltage "power supply" could have a short and that would cause the symptions you describe
But if you want to try the power supply your self you can call Pioneer and give them the model number and they should be able to get the information you need.
tvkirk
Dec 24, 2008 | Pioneer SD-P5795W 57" Rear Projection...
Tv turns off
cant solve, but my problem is identical!
Oct 05, 2008 | Pioneer SD-P50A3-K TV
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
Need help
A power supply is a very complex circuit that changes the voltage that comes from an outlet to voltages the tv can use and is a circuit that need to be repaired because in Tv's is only a section of a circuit board and the rest of the board has other functions. Computers use a single module that you can replace as a whole but not tv's.Be safe an call a qualified technician because there is danger involved.Get an estimate.
Sep 17, 2006 | Pioneer SD-P5795W 57" Rear Projection...
Pioneer SD-P5795W 57" Rear Projection Television Logo
Top Pioneer Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
