HP Compaq Presario CQ50-110US Laptop Logo
Posted on Feb 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
BLANK SCREEN MAYBE THE VGA CARD? pLEASE HELP - HP Compaq Presario CQ50-110US Laptop
daveyboy-uk
Level 2:
Scholar:
  • Expert 73 Answers
  • Posted on Feb 23, 2010
daveyboy-uk
Expert
Level 2:
Scholar:
Answers
73
Questions
0
Helped
24510
Points
228
Hi first thing to do here is to see where the problem lies. use a vga / monitor lead from your laptop to an external monitor or lcd/plasma tv in pc mode and by pressing fn and your monitor switch key think its f5 you should be able to determine if your screen is at fault, a common problem is the screens inverter or backlight bulb, if you manage to get an image on your external source then you its sure to be screen related wether it be the inverter/backlight/or even your internal screen lead this process can save money and time, you would then need to test the inverter to see if its this, the inverter is normally the cheaper option as the backlight can be a long tricky process.
I hope this has helped please rate :)
My video card type ax-8300gs/512d2 cannot function. lcd screen blank
There is problem in VGA Card. 1st you change your VGA Slot. If the problem exist Replace the VGA Card or have a local tech take a look at the VGA Card. VGA Card Drivers
2helpful
My computer wont let me into the bios when i start it up all i get is a blank screen i dont even get the bit where it tells you what buttons you press to get to the boot menu my screen is just blank
you have a problem with your screen / onboard graphics / graphics card / vga cable ...
wiggle the cable for starters then maybe try another cable or screen
rate if useful
Compaq Presario desktop with blank screen
Reset or Clear CMOS because maybe it hang-up some devices that are plug-in to. You can do that by removing the Lithium Battery on the Motherboard. This tips are only technician can do that but to solve your problems like this, this is a tip. And also check your Memory Module.
Hope this might help you, good luck!
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
My HP Pavillion will not load windows. Goes to a blank screen. It will run in safe mode though. Please help
...look like that your VGA card had a problem...unplug the power cord from your CPU and then...if you know how to open the case of the CPU then you can try to take out your VGA card from the motherboard...cleaning the VGA pin with soft and smooth cloth...then put it back to the motherboard...and also try to take out your memory from the motherboard and use the same as you cleaning the VGA and put it bank in the motherboard...and then try to turn in on again...if it's still a problem then try to use your VGA card to other motherboard and test it...if the problem still persist then you have to buy a new VGA card...
My monitor is blank?
Could be you monitor or vga card have gone bad. If you have a known working monitor connect it to your pc & see if it show something. I fit does, your old monitor maybe bad & maybe replaced. If it doesn't show anything, you vga card maybe bad. You can replace the vga card which maybe the culprit.
My toshiba laptop blank screen
hi try using ur vga port to output to a moniter if this works ur inverter is knackered if not maybe screen graphics or inverter.
2answers
Acer Aspire 5720Z Notebook - Screen flickers, goes blank then comes back on when screen/lid is adjusted
It is most likely the connector between the screen and the motherboard that is loose/failing. I would check that first, before taking it in for repairs..
3helpful
2answers
How to re-enable VGA display it was disabled accidently
in bios settings there is a option enable or disable onboard display card check , one more option is there press F8 key when you are restarting the system some options is come their select enable vga mode
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
