Question about Linspire My First LeapPad Pen: LeapFrog
My First Leap Pad does not recognize the cartriges. The error when the game is turned on says "Oops, that's not a My First Leap Pad cartridge". The cartriges are correct and plugged in firmly. The batteries are also new. Is there a way to fix it?
Posted by bhilke on
  • Amber Sep 01, 2013
    Mine reads the cartridges but when you touch the pages with the pen it gives incorrect responses...... whats that all about?
  • BDazzled Designs Jun 18, 2014
    Try cleaning the stylus with rubbing alcohol.
Anonymous
    New Friend:
Believe it or not, just blowing on the cartridge and inserting it again seems to do the trick with our Leappad.
Posted on Mar 11, 2010
BDazzled Designs
    New Friend:
  • 19 Answers
Take a Q-tip, wet it with rubbing alcohol and gently rub around and across the metal "prongs" of the cartridge. Let it dry thoroughly before inserting back into the LeapPad. Also clean the outside of the cartridge port with alcohol.
Posted on Jun 18, 2014
My leap pad 2 freezes as soon as you turn it on what do I do?
Reset it as it has a error in loading stages send the company an email from you and tell the your issue Also take one cartridge out and try another The game cartridge may be dirty
Apr 12, 2014 | LeapFrog Leap Frog Read Aloud Leappad...
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
Leappad won't recognize game cartridges and when it does, the screen goes black and returns to home page
I used the pencil eraser first on each of my daughter's cartridges. Then I used a qtip to rub them with rubbing alcohol. Finally I used a blow dryer to blow out where the cartridges are installed and now her games are working just fine.
Dec 29, 2012 | LeapFrog Leap Frog My First Leappad...
My leap pad won't recognize any of my books. When I put in a new cartridge it says, "Oops! That's not a leap pad cartridge!" If it does comprehend me pressing the green go button, it starts reading a...
I just had the same exact problem. We followed the leap pad recommendations for cleaning the stylus connection. Then we used a q-tip to clean the cartridge port and blew into it. Now it works.
Oct 23, 2010 | LeapFrog LeapPad Learning System:...
Leap frog doesn't read the cartridge
Blow the cartridge opening out with a blowdryer.
Jan 17, 2009 | LeapFrog LeapPad Learning System:...
MP140 do not recognize cartrige
Ensure that you are using original cartridges.
Clean the cartridge sensor inside the printer ink carriage with isopropyl alcohol and cotton. From description it looks like a faulty cartridge contact.
The cartridge sensor is the metal plaque that connects to the cartridge chip, is located inside the printer carriage.
Nov 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
I purchased a Leap Frog Read & Write Leap Pad Learning System in
I took the entire toy back to the store where I purchased it and exchanged it for a new one.
Nov 11, 2008 | Toys
CANON FAX JX200
remove the cartridge and see if it goes away, if does then you probably have a defective cartridge are are not inserting it correctly.
Thank You,
Mikey
Apr 04, 2008 | Canon FAX-JX200
What does the question mark mean on the screen of the leapfrog leapster when you insert a new game
Dose not reconise cartrige or not compatible.. I would say it has a fault it the above are not so
Dec 25, 2007 | LeapFrog Leapster Electronic Book:...
Linspire My First LeapPad Pen: LeapFrog Logo
1,724 people viewed this question
Top Linspire Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Linspire Computer and Internet Expert? Answer questions, earn points and help others
