Question about Fisher and Paykel DE09 Dryer
Front load dryer make a horrid squeaking sound as it goes around. Heat's great - it just squeaks!
  • 262 Answers
There are nylon or cloth type guide bushings(bearings) at the front of the drum which may be worn. The drum rides on these to keep it suppurted. You can replace from retailer and or try to lubricate with silicone spray.
Posted on Feb 23, 2010
    New Friend:
  • 42 Answers
My DE09 was doing the same thing. I took it apart and found as stated by wfservices, that the slides that the drum rides on were worn / damaged. In my case, the bearing support was broken as well, right where one of the white slides sits, and that allowed the slide to move out of position. I was able to buy the replacement parts at http://www.fisherpaykelparts.net/category/DG09/DE09-DG-09-US/1.html. In my case I had to get the WE3M26B bearing kit, because I needed both the bearing support and the slides. But if you only need the slides, they sell those individually as well.
Posted on Mar 16, 2010
SAMSUNG steam moisture sensor front load dryer has noises coming from it. Need help to pinpoint possible problems and how to fix.
You may have a roller out of alignment or off track with the drum now if you took the front panel off. Check to make sure the rollers are on track and the front slides may need t o be replaced if your dryer is a 2 roller model.
Feb 08, 2017 | Samsung Dryers
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
My Kenmore front loading dryer squeaks loud now when I start drying clothes. I clean up around the dryer and took the vent off and cleaned the lint and particles out of the vent and vent tube.sometimes it...
either the bottom pulley or the rollers are whats making the squeking noise you can buy a dryer belt kit which comes with two rollers pulley and a new belt for around 25-30 from marcone appliance
Jul 12, 2010 | Dryers
Dryer squeaks like crazy.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 27, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer squeaks upon starting to dry a load of clothes...everything else works fine except it squeaks the whole entire time. Any advice?
GE dryers have a straight rod in the back center of the drum that goes through the rear bulk head and that is what supports the drum in the rear, it is also what squeaks when it gets warn out , around that short rod that goes into rear bulk head from the drum is a black Teflon plastic sleeve called a barring replace it and that will fix the noise
Apr 05, 2010 | GE DVL223EBWW Electric Dryer
Squeaking Sound like the fan belt needs replacing.
heatman101
Apr 05, 2010 | Hotpoint TDL14 Electric Dryer
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
May 31, 2009 | Frigidaire GLER341A Electric Dryer
DCXR463GA2WW Squeak
YOU MOST LIKELY HAVE A REAR DRUM BEARING FAILING. IT IS A SMALL TEFLON BEARING THAT SLIPS ON OVER THE REAR SHAFT OF THE DRUM AND INTO THE HOLE IN THE REAR OF THE DRYER. THERE ARE ALSO FRONT GLIDES THAT SUPPORT THE FRONT OF THE DRYER. OLDER DRYERS HAVE THE FRONT SUPPORTS UNDER THE DRUM SO THE DRUM RESTS ON THEM. NEWER G.E. DRYERS HAVE A PLASTIC RING WITH THREE TEFLON GLIDES ON TOP OF THEM AND THE DRUM HANGS FROM THESE GLIDES. REPLACE ALL OR SOME OF THE ABOVE PARTS TO ELIMINATE YOUR SQUEAK.
ON OTHER POSSIBILITY, THE IDLER PULLEY THAT KEEPS TENSION ON THE BELT CAN BECOME A SQUEAK MAKER.
Apr 07, 2008 | GE DCSR483EA Electric Dryer
Fisher and Paykel DE09 Dryer Logo
6,665 people viewed this question
Top Fisher and Paykel Dryers Experts
Nathan Van Boven
Nathan Van Boven
Bill Eager
Dennis Boxerman
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
