Question about Dometic Rooftop RV Air Conditioner
We have a 2005 Country Coach Allure with 3 Dometic rooftop air conditioner/heat pumps. One of the units will come on start to cool then quickly turn to heat then cool then heat. What could the problem be?
Posted by dtresham1 on
Anonymous
    New Friend:
  • 66 Answers
Remove top cover of units. clean coils, and filters.A.C. units , and heaters must breathe.If coils are dirty ,system cannot breathe properly.Also, systems should be cleaned yearly,at least.
Posted on Feb 23, 2010
Anonymous
    Scholar:
    New Friend:
  • 99 Answers
Hi; Sounds like a problem with the tstat or the defrost sensor. Also have these units been cleaned yearly. Also if the differential between heat and cool is small this will cause the unit to cool then heat due to the low differential at the tstat...alpharome416
My 2 zone ac/furnace/heat pump system is not showing zone 2 at all. where should I start to look for a problem?
I assume you are seeing this at the zone board at the unit?
How many zones can a 20-40 ft RV have? seems silly
is 1/2 the coach not getting any thing?
post the model and serial number.
Sep 22, 2013 | Dometic Rooftop RV Air Conditioner
Does not cool the coach enough
It is one of a couple of things. Either the air conditioner4 needs recharging, the compressor is not coming on, or the ac unit is to small for the coach.
Aug 04, 2011 | Dometic Rooftop RV Air Conditioner
I just had a new a/c - heat pump installed on my 5th wheel. The a/c works well but when I turn on the heat pump it seems to blow air about the same temperature as inside the coach. I seem to hear the...
Hi; I hope You called a company that will honor any warranty on the heatpump. Sounds to Me like I would contact the original installer for more help or free replacement.Also at 55 or 75 degrees outside The heatpump should be providing toasty air. Only at close to freezing temps will You get a reduction in warm air and then the heat strips will help out then also check to see if the unit has outside air dampers and make sure they are closed..alpharome416
Feb 23, 2010 | Dometic Rooftop RV Air Conditioner
Dometic a/c on fifth wheel with comfort controls
First lets address the heating issue. These are not furnaces but are known as "Chill Chasers" and are not designed to "heat" your RV Attempting to use them as a whole coach heater will burn them up in short order.
Your A/C sounds like the coils are freezing up. There is a small probe that is placed into the coils. you can see it from under the unit if you remove the interior cover - a little 1/8" in dia. silver piece flattened on one end to slide between the coil fins with a wire going back to the control box
It may have fallen out
Sep 29, 2009 | Dometic Rooftop RV Air Conditioner
Dometic AC that the fan shuts off but the compressor keeps running
call dometic dealer. I hear they have a bad circuit board that is replaced.
Jun 02, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
127 people viewed this question
Top Dometic Heating & Cooling Experts
Marvin
Marvin
Sheldon Dedek
Mike
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
