Buy unlock codes, cheap price.. for Samsung (any Network provider) phone you need to bring or send your phone to
our shop for unlocking.. we use Special Gadget tools & cables
or Remote Unlocking by IMEI+operator
Direct unlock codes, No downgrade, Flashing or Formatting, No losing data. (100% Safe/Professional)
We Openline All kinds of Samsung phones
email: [email protected]
+639393688886
SOURCE: how to unlock sgh-a737
the best way to unlock your A 737 is This.... works on all locks and address book passwords. Go to AT&T in person ! put a new SIM in from AT& T with zero balance . ADD funds for prepaid OR contract . 15.00 25.00 PIN TIME. From AT&T no where else! Then have them send a update flash to your fone. Customer Service will SAY the update dosn't do anything. Trust me it resets the entire phone and Formats to a New Phone . Screw typing in countless #### & Letters. Your not gonna get it. If you leave the store and your phone does not work . Just show up everyday until does work . Do not call at&t on the fone for help. you will burn your quite a bit of time calling 1800 ###"s and spend 4-5 hours sitting on hold all day . No one at at&t knows anything about Locks on a A737 this is all they know eight zeros manufacture Reset, that dosn't even work!!!!! UNREAL!
SOURCE: SAMSUNG A737 UNLOCK NEEDED!
On the AT&T Network, to unlock the Samsung A737:
*The 8 digit code can be obtained by calling AT&T Technical
Support and given the representative the IMEI number. In exchange they
will give you the Subsidy Unlock Code.
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
SOURCE: samsung sgh a737
FOR PEOPLE WITH PHONE FREEZE ON SAMSUNG- the #7465625*638*code# is not needed when you have the phone freeze just follow below.
I know how frustrating this was and i got it done by myself by experimenting since everything cant be googled that easily. i figured i can help anyone out. this has worked for 5 phones that i have done my self so 5 for 5 YESS!!! This is as satisfiying to me as watching micheal jordans final shot!
any ? contact me at [email protected]
ok i figured it out. for all those people that have gotten the dreaded phone freeze om samsung propel a767 or any other samsung phone so far not sure about touch screen.
first look for a local unlocker in ur area or somewher that can provide the codes and get the unlock code and phone freeze code. mine was only 20 for both and took less than 24 to retrieve. email me for his info.
insert sim that you want to use (tmobile). you get the screen which says phone freeze. type in the freeze unlock code which was given and the press the att logo/menu button.
**YOU WILL NOT BE ABLE TO SEE THE NUMBERS YOU ARE TYPING SO KEEP TRACK OF WHAT YOU INPUT**
after you have entered number and pressed button then you will get a network lock screen. this is where you type in ur unlock code. type that in press confirm and BAMM!!!! you are now able to use tmobile sim
Open the Samsung A737 page at any of these sites: My Unlock Code, GSM Liberty, Unlocking.com or Mobile Unlocked. All four of these are pay sites. Mobile Unlocked and GSM Liberty offer money-back guarantees in case the code will not unlock the phone.
Remove the Samsung A737's battery. When the site you chose in Step 1 prompts you for it, type in the International Mobile Equipment Identity (IMEI) number from inside the Samsung A737's battery compartment. Every site in Step 1 needs the IMEI to generate an unlock code specific to your phone. Pay for the unlock code. In case you do not use a credit card, most of these sites will accept a PayPal payment. You will receive the unlock code by email, usually in a few hours, depending on which site you chose.
Slot the old carrier's chip into the battery compartment, in case the unlock code will not work without it: some unlock codes are network-specific. Put in the battery and close the battery chamber.
Enter your Samsung A737's phone mode. Type on your keypad the code precisely as it appears in the email. If you receive the unlock code "A5966J Send" for example, then type in 259665, and then "send" the code to your Samsung A737 by pressing the Talk/Call/Send button.
Slot the new network's chip in under the battery. Make an outgoing call to test if the phone is now unlocked. If the call does not go through and a chip or SIM error message pops up, repeat Steps 3 and 4 a few times. If you still cannot make a call, contact the code provider so they can remedy the problem.
