Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
I am starting to see blue around the screen - Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Posted by gygray on
Radames Pagan
    President:
  • 196 Answers
Optics unit block bad
Posted on Feb 26, 2010
Anonymous
  • 135 Answers
Optical block problem
Posted on Feb 23, 2010
Anonymous
    New Friend:
  • 26 Answers
Replace optical block unit, Sony had a recall on this, but it might have expired last summer
Posted on Feb 27, 2010
1helpful
The pc starts and loads.Then the blue windows xp screen comes up and it wont do anything else exept let me move my mouse pointer around the screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then you need to update all your drivers and install all windows updates from Windows update and scan your computer for viruses!And I also suggest you to run CMD as administrator and write in CMD without quotes"sfc/scannow"
this will fix blue screen error.
If problem still exists, then get the reliable program like PC Fresher to fix your annoying blue screen problem.
It has blue dots in the middle of the screen
This is a defective Light Engine Assembly. The average cost to replace it is around $650.00
The screen has a blue like tint around the edges of the screen..what can i do? it's a magnavox 6p6030w101 60inch projection tv.
you have coolant in your red, green, and blue picture tubes. this coolant will start to turn dirty as time goes. the coolant should be clear but when it starts to turn, your picture has like a haze in it. coolant needs replacing. suggest local service center
Blue color on screen
If mostly blue shadow appears around the white objects means the cooling liquied is getting dirty and needs to be replaced.
My compaq Presario V6000 will not start windows, it continously loops to an options screen with the following start options; Safe mode, safe made with networking, Safe mode prompt command,Windows last...
what you are describing is the blue screen of death, meaning theres a hardware or software problem, try to boot into safe mode and perform a system restore, if that doesn't work use your XP cd, let it load the drivers and the ask it to fix the existing XP installation, anything that you have saved in my documents should be safe and the problem should be solved. If the blue screen reappears then you have a hardware problem
2answers
The tv screen is 60% blue . . . . . .
Me too! Is this a related light engine problem that people are experiencing with the "red cloud" in the middle of the screen? I just replaced the lamp, which I thought was the problem, but nope, the blue is still there. So definitely not the lamp. I don't know what to do?
Thinkpad R51 Blue screen
First:
does this also happen in safe mode boot. (press F8 just before windows boots). If not then go to your event viewer and check the messages at the specific time,hour messages. for example. computer booted at 23:30. in windows around 23:31:10 and then blue screen. Go to safe mode. and look in the logs what registered at 32:31:10(around this time).
If not possible to boot in safe mode. Try to remove one of the 2 memory dimm(if you have 2). so you boot with 1. maybe 1 of them doesn't work good anymore.
Blue Menu Screen is always there
Dear All
This problem is caused by keyboard switches which are bad quality they are easy to replace, so if you are able to work with solder you can finish replacement in 15min.
Good luck.
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
