Freezers Logo
Posted on Feb 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, my whirlppol fridge started leaking..from the freezer. It is only 3 years old. Any idea whetehr it is something I can fix myself or should I call a technician to get it fixed?
Anonymous
Level 2:
  • Expert 523 Answers
  • Posted on May 05, 2010
Anonymous
Expert
Level 2:
Answers
523
Questions
Helped
134561
Points
944
The drain is plugged up you can un thaw it your self
My 20 cubic foot fridge dairy upright freezer has started leaking small puddles of water underneath it is only 3 months old
Contact shop, less than a year old they are responsible for repairs / replacement. Have you read instructions to make sure that you have done all that you should regarding any draining of system thet is required.
Feb 22, 2016 • Freezers
Ice forming at bottom of Daewoo freezer. How do I fix this
Look on the back of the unit for a plastic hose coming out the bottom to a drain pan usually sat on top of the compressor. Bend a straw and push up inside. If it won;t go, there is a blockage, usually ice in the drain. Fully defrost the freezer and blow through the straw until clear.
Gladiator fridge/freezer-freezer not cold enough, stays at 10 deg
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
1helpful
1helpful
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Whirlpool FRS Side by Side Fridge Freezer
Hi Simon I saw that problem because you have a hole in the bottom of the freezer connecting directly on the wall of the fridge you need to block it ... because the air flow directly from the freezer 2 the fridge . Hope it was helpful.
Francois
Candy fridge freezer
It sounds like a Freon leak. The compressor is running and it gets a little cold. THis is not something you can fix yourself. You have to have certification to buy freon and gauges and know exactly how to use them. Besides in most cases you can't find the leak and will have to keep recharging it.
Jun 28, 2008 • Freezers
Leaking Water
rakenrol...asteeeeg !!
Feb 19, 2008 • Freezers
2answers
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Top Whirlpool Freezers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
