Candy F248P Electric Single Oven Logo
Anonymous Posted on Feb 22, 2010
CANDY OVEN Hi, i have candy oven which stop heating up even if it switched on for 10 min still cold, though fan & oven light works.
Barry Coates
Level 3:
  • Candy Master 3,463 Answers
  • Posted on Feb 22, 2010
Barry Coates
Candy Master
Level 3:
Answers
3463
Questions
Helped
1412651
Points
12766
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Testimonial: "GR8 JOB HAVE ALREADY SEARCHED ON THE NET BUT THIS CONFIRMS. NICE ONE CHEERS."
How-2-Repair.com
Level 3:
  • Candy Master 746 Answers
  • Posted on Jan 30, 2014
How-2-Repair.com
Candy Master
Level 3:
Answers
746
Questions
0
Helped
594977
Points
1880
Candy Oven not heating? How to replace a Candy fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
2answers
Candy oven FL134 n uk will not heat up! (Since I had a power cut) The grill is working fine
I think that should be checked round heating element (RC) and change over switch (CO).
Dado
Feb 13, 2015 • Candy Ovens
2helpful
2answers
1helpful
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 • Ovens
1helpful
3answers
Hi. My oven stopped getting hot (elements still get barely warm) right after the temperature sensor broke off. Could the broken sensor cause this? Thanks.
yes it can and ur element is probably bad shut off power take out 2 screws on side of it n pull ito ut to disconnect wires n put new one in !!
Apr 07, 2011 • Ovens
1helpful
2answers
My candy oven r43/3xuk wont switch on. The power
If the fan is working o/k then it is likely to be a faulty oven element if it is a
electrically heated oven.
If it were the timer, not even the fan would work.
Mar 28, 2010 • Ovens
2answers
When i switch the oven on the oven trips the main circuit. the oven used to work normal then it started to trip out after it had been on for a long period. you could leeave it off for 10 mins then it would...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
2helpful
De Dietrich electric oven has power but no heat
hi it is probably the timer not making the switch properly even though it looks like its on stopping power going to the thermostat
Dec 11, 2009 • Ovens
2answers
The fan in my oven is blowing out cold air and while the convention oven is working- it takes a long time to heat up and doesnt cook food as well as the fan assist
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for element How to Repair Home Appliances
Dec 11, 2009 • Candy Ovens
8helpful
3answers
Oven switches 'itself' off without the timer
I sorted it it is a simple solution, if you take the top of your oven you should see the problem...it will be big and black..dont spend a ortune getting it sorted i brought the part off ebay for less than a fiver.. just cant remember what it was called..very simple to fix though.  Mike
Top Candy Ovens Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
How-2-Repair.com
How-2-Repair.com
Are you a Candy Oven Expert? Answer questions, earn points and help others
