I can't fax out. I dial the number and get a fast busy even though I know the number is not busy as I can reach it on my regular phone line. I have checked the lines, unplugged and replugged everything and still nothing works. This applies to domestic and international faxes. HELP!
Check and eventually replace the phone cable. The fax machine must be connected using a two-conductor phone cable such as the cable pictured below at the left:
Since you mentioned that you have an outside line, do you have to use a code to dial out normally? Try plugging in a phone to the line for your fax machine, and attempt to dial the number for the other fax machine using the phone. You should reach the fax and hear a high pitched sequence of tones. This is the other fax machine trying to establish a connection. If you still get a busy signal, try calling the owner and letting them know that their fax machine is not accepting incoming calls.
Dial the number on a regular phone and verify that the number ANSWERS with the fax tones immediately. If it doesn't, then the line will register as busy to your fax.
This could be related to the fax machine, but more than likely it's a phone line issue. Try sending a fax manually by using the fax machine's speaker or "on-hook", then manually dial the number. Listen carefully as the machine dials and make sure it's even dialing out. Do not hit start until you hear the other fax machine pick up. If the "fast" busy signal occurs before dialing is complete or right after, have your phone line checked.
