Screen shows "incorrect paper size". All faxes are now just being received in memory. I can't get it to print the document even if I change the paper size setting. Also, I pulled the plug on the machine, but still it came up with the same message on the screen after plugging it back in.
Alarm light (red) is flashing.
SOURCE: Received in Memory
check the paper sensor at the bottom of where the paper comes out! this has a tendency to pop out of its little holder. Use a flashlight to see it! the sensor is blocking the beam.
SOURCE: Fax L200 Check paper size problem
This is due to the reg sensor being worn, item 26 in the photo
please order and replace
RB2-1700-030 - LEVER, REGISTRATION SENSOR
hope this helps
SOURCE: It is stating that incorrect paper size and I cannot get it cleared out
Your memory might be too full. Try to delete your memory and see if that will help.
SOURCE: We have a Canon Faxphone L170. Someone sent a fax
On the controll panel there is a diamond shape picture with a eye in it.press that bottom and clear the fax that you received.There is no other way.You will have to phone the sender and ask them to change the papersize settings on the fax machine.
SOURCE: Canon ImageClass D680 "Incorrect Paper Size" error message
Hi, please get new driver here:
www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay kbxlz
