Installing a third-party image editor or viewer applications may sometimes hijack the image file associations. In such circumstances, you could use this utility to repair the file associations (following image file types) to Windows XP defaults.
Click on
Download utility and Click on RUN and then once again RUN
Check All the files and then click on Repair Associations
Download Utility
For the CD DVD Issue
Step 1: Unplug any cables that are connected
loadTOCNode(3, 'moreinformation');
a.
Unplug any cables that are connected to the video outputs of the computer.
b.
Try to read the disc again.
c.
If you still experience problems with the disc, go to step 2.
Step 2: Update the DVD driver
a.
Contact the manufacturer of the DVD Drive to obtain an updated driver for the DVD drive, and then follow the manufacturer’s instructions to install the driver.
b.
c.
If you still experience problems with the disc, go to step 3.
Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder
a.
Contact the manufacturer of the DVD Drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer’s instructions to install the decoder.
Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie.
b.
c.
If you still experience problems with the disc, make sure that the sound card in the computer is compatible with the DVD drive.
Note Hardware and software decoders usually need a sound card to play back DVD movies.
d.
e.
If you still experience problems with the disc, contact the manufacturer to obtain a new disc. .
Remove Duplicate Drives
loadTOCNode(2, 'moreinformation');
Remove any duplicate CD-ROM or DVD drives being loaded by Windows. To do this:
1.
Click
Start, point to
Settings, and then click
Control Panel.
2.
Double-click
System.
3.
On the
Device Manager tab, click
View Devices By Type.
4.
Double-click the
CDROM or
DVD branch to expand it.
5.
Note the properties for each device listed in the branch. To do this:
a.
Click a device, and then click
Properties.
b.
Click each tab in the device properties dialog box, and then record the device information and settings.
c.
Click
OK.
6.
Click
OK, and then close
Control Panel.
7.
Restart Windows in Safe mode. To do this, use the appropriate method for your version of Microsoft Windows.
