Question about RCA 32V550T 32" TV
There can be several causes for this, few of which you can do anything about. However, a few things to try.
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Good luck with your problem...I hope you can work it out.
Posted on Mar 31, 2010
SOURCE: TV turns on by it self then constantly changes channel
the controler brain has to be replaced main bord
Posted on Feb 03, 2008
SOURCE: rca 24t511t 24" issues
CHANGE ALL SWITHES ON CONTROL PANEL, POWER, BOTH VOLUME UP AND DOWN AND CHANNEL UP AND DOWN. THEY ARE LEAKY
Posted on Apr 03, 2008
SOURCE: RCA F32650 TV changes channels by itself
Problem is common to RCA models. The issue is bad solder joints in the tuner area. Resolder the entire tuner section of the board and the problem will be resolved. No parts are necessary.
Posted on Aug 29, 2008
SOURCE: rca turns itself off and on and scans thru all the channels
I have an easier solution, First I want to thank those who posted the solution that the problem is on the small switch board mounted right behind the switches under the picture tube. I figured that might be where the problem was but it's better to to see it confirmed. I thought the problem was more complex like maybe an IC chip got zapped or something but there are none on that board. Only 6 switches, the infared sensor, 1 capacitor and some resistors. I am convinced that in my case at least the problem is caused by humidity. It happened last year constantly durring humid weather in the summer and only a couple of times over the winter when the air is dry and cooler. I did figure an easier way to disconnect all the switches without unsoldering. After you remove the board, flip it over to the solder side and see where the wires connect. You will see them labled GND - KEY - +5 v - LED and IR. The one you want is labled KEY. You will see on the other side this wire is second from the end . Just separate the wires a bit and cut it. That's it. Just be sure it is the one marked KEY. This wire goes thru a series of resistors and the switches and nothing else. Just cut that one wire and put a piece of tape over the cut ends and thats it. it's a lot easier then unsoldering all 6 switches. And if you do decide at some point later to replace the switches, it's easy to resolder the wires and tape it. I did it this way and my TV is working perfect. I was done in ten minutes. You can only control the TV with the remote but so what, thats all we use 95% of the time anyway. I hope this helped you.
Posted on Sep 05, 2009
