My screen is wide and not formatted correctly. What do I need to adjust to go back to a full screen mode?
  • 11,361 Answers
You need to find out the native resolution of your monitor, then adjust the PC video resolution to that required by your monitor. Brand and model?
Posted on Feb 22, 2010
  • 787 Answers
You need to adjust your scree resolution. You can choose a 1280x800 px resolution if you have a 15.4'' screen on your laptop or other similar resolutions. Usually, widescreen resolutions are all grouped after the normal ones in the resolutions list.
6ya staff
SOURCE:
Would like to record in 16:9 ratio but am not sure of the results? goof or bad?
You may record in either wide-screen or normal mode. If you record in wide-screen mode, the video will appear compressed when played back on a normal TV. For full details refer to the "Using the wide mode" section of the manual on page 32 of the manual.
May 03, 2012 | Sony Handycam DCR-TRV525 Digital Camcorder
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
Sep 27, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
On Sony 36 iinch Trinitron TV, when I go to HDTV channels the picture size changes to widescreen. How do I adjust back to full screen on HD? I tried the "no zoom" button but that doesn't work. Cannot...
Please note that all HDTV channels project wide screen pictures. You can still go to settings and then picture mode and change the format to 4:3/full mode.
Aug 28, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
Screen help
on a ony leave it in full mode and adjust it on the cable box (if you have one)using the format button. In HD you only get a few choices from the TV
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 15, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Cannot adjust picture
There should be a screen mode button on your remote. Full, Wide, Zoom, and Etc. Sounds like your putting a 4:3 video into your 16:9 screen. Which causes the normal "box" video to be stretched to the wide "rectangle" video. Just keep the screen mode on Full or Normal. You should have empty spaces on the sides of the video and when a HD program comes on, the sides should fill in automatically.
Jan 28, 2009 | Vizio GV42L 42 in. LCD Television
Went Wide Screen - how do I get it back to normal?
All TV stations in the US are going digital in the next 11 months, and the format most have adopted is exactly what you describe...accordianman
Feb 27, 2008 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Wide Screen vs Full Screen
look for screen format in video mode menu or if you have original remote you have that option in your remote
Jan 17, 2008 | Hitachi 43FDX01B TV
Sony Bravia - Picture in ZOOm Mode
I corrected mine by adjusting my cable settings. It had been set to "zoom" / "wide" mode. I reset to "normal" and now channels look fine again.
Dec 30, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Computers & Internet Logo
423 people viewed this question
Ekse
Marvin
Marvin
