Question about Cyberhome CH-DVD 300 DVD Player
My TV has only the audio jacks (yellow and White) not the video jack (red). Is there another way to hook up the Cyberhome 300?
Posted by katherine287 on
Anonymous
    New Friend:
  • 4 Answers
Yellow is video. white is left audio. red is right audio. just match the colors and leave red unplugged.
Posted on Mar 01, 2010
Anonymous
    New Friend:
Use the yellow jack to get the picture and the white jack to get sound. It will work on your T.V.
Posted on Feb 23, 2010
I get the audio but video does not come on
hi.... is your player works on RCA connector? if so the audio jacks colored red and white should be inserted to your TV RCA port colored red and white too..the video jacks is yellow try re insert it to your TV RCA port colored yellow....weak video responses sometimes cause by delayed contact...hope it can help...don't forget to rate and vote...good day..
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
What is required to hook up my cyberhome 300 to my television i was given the unit with only the plug in electrical cord no other cords what else do I need to get to make it work thanks patrick
red/white & yellow cable wire....connect to tv/monitor by color...depending on what jack u plug into on tv (to watch you will have to tune that ch 3/aux/video)...
I need a remote control and i need to know how to hook my cyberhome to a tv. Its a use one
you need to purchase cable wire (yellow/red & white) at least 3 feet..yellow is video red & white is audio...plug into the color jacks on tv...the remote is kind of hard this dvd model is discontinued....
2helpful
Hook up portable dvd player to tv
If you have component out jacks in the back (yellow, white, red plugs) you should be able to buy plugging them into your TV's Component IN jacks.
Hook up not right
You may have connected the video cable to the (red) component jack. The three component jacks are always next to each other and are color coded red green and blue. The composite video jack is color coded yellow and only one cable is used for video. If you are using the component video, three separate cables are required.
3helpful
2answers
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Can i hook up PS2 using only the white and yellow jacks?
i download and read your owner manual .
http://www.funai-corp.com/6pdf/om/DWT1304.pdf
i do see you only have a video and a mono sound input jack , so , your ps2 as in all RCA style jack inputs , yellow is video , red and white is audio , i will assume you have yellow plug in video and red or white in audio , and on your TV remote you hit the GAME button , i'm suprised they don't use the term VIDEO , but , anyway , are these the steps you have taken ?
Polaroid tv Wii connection
Your LCD TV should have one of the following types of inputs:
  1. Composite. This is usually a yellow jack, along with red and white jacks for audio.
    If your TV has these, which it should, then the cable that comes with the Wii will plug directly into these jacks. Plug the yellow to the yellow jack, the red to the red jack, and the white to the white jack.
  2. S-Video. This is a flat black jack. There are four little holes, and one "flat" rectagular hole. There should also be a red and white jack that go along with this for audio.
    In order to connect to this input, you will need to purchase an S-Video output cable for the Wii. Most stores that sell Wiis will sell a third-party cable for this.
    This connection will give you a significantly better picture than Composite.
    S-Video does not carry audio, so you still need to plug the red plug into the red jack and the white plug into the white jack or you'll get only video and no audio!
  3. Component video. This is a triplet of Red, Green and Blue jacks. There is usually a set of red and white jacks along with them for audio again.
    This connection will give you the best picture, and you can set your Wii to EDTV (Progressive) mode.
    To connect to this input, you will need to get the Wii Component Video cable. Most stores that sell Wiis will either sell the official Nintendo one, or a third-party cable.
    Connect the red plug to the red jack, the green plug to the green jack, and the blue plug to the blue jack. Also connect the red audio plug to the red audio jack and the white audio plug to the white audio jack.
    Be careful not to get the red audio plug confused with the red video plug!
    If you see a picture, but the colors are wrong, then you either swapped the red and blue, or you connected the red audio plug instead of the red video plug.
2answers
DVD player hook-up problem
Using the composite video connection method is pretty straightforward. you will be dealing with one video cable (marked in Yellow), and two audio cables (marked in White and Red) Red is right channel and white is left channel if stereo, if mono use the white marked cable. Look at the back of your DVD player you will see the video out RCA jack (marked in yellow) plug one end of the video cable into this jack, the plug the other end of the cable into the TVs Video In jack (marked in yellow) Then plug the audio cables into the Audio Out RCA jacks of the DVD player Red marked cable to red jack White Marked cable to white jack. After this is done plug the ends of the sother side of the cable into the Audio input of the TV white to white, red to red. At this point you should have video and audio once you set the menu of your tv to accept input from the Composite input and the audio jacks. I hope this helps.
Cyberhome CH-DVD 300 DVD Player Logo
Top Cyberhome Televison & Video Experts
 Francisco Mauricio...
Ekse
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
