Question about Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier
Our de-humidifier is running cool but there is no water in the bucket, should there be?
Anonymous
    New Friend:
  • 66 Answers
Is it warm outside,and do you have your A.C. on? Dehumidifiers ,just like A.C. systems, remove humidity. If the weather is cold, put an open gallon of water in front of your unit and let it run a day or so. If the bucket gets water in it, and the container of water goes down, then the unit is working.
Posted on Feb 22, 2010
Testimonial: "Thanks for the info. will try that solution."
Water does not fill in the Aprilaire humidifier on my furnance
It sounds like the feed has been shut off or pluged. Be sure the feed is off, remove the feed from the humidifier. open the fill valve slowly and run water into a bucket or whatever. If it does not run you found the problem, if it does then it is probably the fill solenoid valve on the humidifier.
Mar 21, 2014 | Edison 40 Pint Dehumidifier
The De-humidifier thinks the bucket is full constantly
This occurs when either the float valve in the top of the water collection bucket is stuck in the UP position or the bucket was not installed properly, making contact with the bucket safety removal switch on the rear wall of the bucket holder.
Checking an correcting those 2 issue should solve the problem. Be sure to turn the unit OFF & unplug it before attempting corrective issues.
Hope this helps you & thanks for choosing FixYa.
Sep 09, 2011 | LG LHD65EBL Dehumidifier
Classic dehumidifier cdr4500e blowing hot air
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 12, 2011 | Danby DDR2509EE Dehumidifier
It looks and sounds like it works good but it is not pulling any moisture out of the air. It will run for days and there will only be a little bit of water in the bucket?
the refrigerant r134a has leaked out,you need to have it recharged,this is normal for most de-humidifiers after 2 to3 years of use
May 13, 2011 | DeLonghi DE400 Dehumidifier
When my dehumidifier is on, it says there is 90 humidity. I come back an hour later, it is still running and no water in the bucket.
If there's no water in the reservoir, first make sure that water is getting to the humidifier. The humidifier must have a good stream of water available to it. If there's water in the water line but the reservoir doesn't fill, replace the float mechanism inside the humidifier.
Take care.
Jul 29, 2010 | Haier 45-Pint Dehumidifier
Wont run through attached hose
my unit runs but does not de humidify
Aug 03, 2009 | Whirlpool Dehumidifiers
How to clean filter
The de-humidifier is a niche product. Its only job is to remove moisture from air to alleviate the problems of mould and mildew. It is very similar in operation to a window air conditioner.
A dehumidifier though will add heat to the room, while an air conditioner will remove heat.
The de-humidifier is an appliance that requires regular maintenance. This may be because it’s icing up, overflowing, not removing enough moisture, or simply time for a good cleaning to maintain its efficiency. If you don’t feel handy enough to attempt this project contact your appliance repairperson.
The following is a step-by-step method used to return your de-humidifiers to its peak efficiency.
Tools required
1 Multi pocket container (old ice cube tray)
2 Long handled brush
3 Oil can
4 Rags
5 De-greaser or spray detergent
6 Selection of screwdrivers
7 New filter
1… Remove water collection bucket and put aside.
2… Remove the filter from rear of machine. Filer is usually within a frame and simply pops out. If no filter proceed to next step. If it is a disposable filter simply replace it with a new one. Other types are made in a plastic frame and can be cleaned and reused. To clean a filter lay it flat in the sink and sprinkle surface with powder laundry detergent. Plug sink drain and turn on hot water. Cover filter with enough water to submerge. Soak for 15 minutes. Remove from water and rinse. Hang up to dry while proceeding to next step.
3… Remove the rear grille from the main body of de-humidifier. If none proceed to next step. If there is resistance then look for hidden screws. If grille locks into cover proceed to next step. Once removed place the grille aside until later.
Tip: Dehumidifier may use different types and sizes of screws. Use ice cube tray to segregate.
4… Remove metal cover of de-humidifier to access inner workings. Cover screws may be difficult to see because are often painted to match body color. Usually two or three screws along each side of base. Once screws are removed lift the cover straight up. Use extreme caution at this point. Front grille may be secured to cover. Some fronts are put together like a puzzle. Parts often interconnect or are screwed to one another. If front grille lifts off with cover try to separate before proceeding. Front grille may lock into groove along front edge of cover. Avoid pulling off any wires from humidistat or indicator light.
5… When cover removed this will expose the heating and cooling coil. They may appear as one but are actually two separate coils in very close proximity. Both will need to be cleaned.
Use a narrow brush to remove surface dust and dirt from the front and rear surfaces of coils. Use an up and down motion to avoid bending fins. Area between two coils must also be cleaned. Use caution, the fins are soft aluminum and can be easily damaged. Once surface dirt is removed, spray with de-greaser or light cleaner. There is a good product on the market called HVAC cleaner. As the name implies it is meant for Heating, Ventilation, and Air Conditioner coil cleaning. If this is not available Fantastic Spray cleaner used in kitchens and bathrooms works quite well. Remove dirt and excess cleaner by slowly pouring warm water into fins. Do not allow the water to enter any electrical connections or components. As an added precaution cover the motor with one of the cloth rags to protect it from the water.
6… With cover, rear grille, and front grilles removed locate fan motor for oil holes. Add a few drops of oil to each end of the motor body. Use a general purpose (3in1) oil or clean motor oil. A #30 oil is sufficient. Three or four drops on both ends of the motor body are sufficient. Add the oil slowly, pausing a few seconds between each drop. If added too quickly over-lubrication will result.
7… Straighten any bent fins. Use a fin comb if available. If no fin comb then use something soft such as a Popsicle stick. Straightening the fins will increase the efficiency of the airflow through the coils. Use caution as these coils are filled with high-pressure refrigerant.
8… Wipe any dirt from fan blade using a soft rag. Do not bend blades. This would cause a vibration that would harm the motor.
9… Vacuum all surfaces including front and back of grille assembly. Vacuum underside of metal cover. Vacuum dirt buildup from base and any other exposed surfaces.
10… Drain any water left in the base and allow it to dry.
11… When completely dry plug in and test operation. On some models testing may require temporary override of bucket overflow switch. Test that cooling coil begins to sweat water within few minutes of operation. If everything appears okay unplug and reassemble. Insert water collection bucket slowly to avoid damaging float switch mechanism.
Jul 17, 2009 | Dehumidifiers
Dehumidifier not sure is working
There is water in the bucket or no water in the bucket? If there is water in the bucket then empty it and put it back. If there is no water in the bucket then make sure the bucket is all the way in, (there is a switch that senses the bucket). If the bucket is not all the way in the de-humidifier will not work. If you do not hear it, it is not working.
Jun 21, 2009 | Dehumidifiers
Bucket fills, doesn't stop
make sure unit is level , the cut off switch will not work if not level
Jun 07, 2009 | LG LD65EL Dehumidifier
Brand New De-Humidifier not pulling water into bucket or hose !
I have lost my manuel. I do not know how to use the hose for when I go away for a few days.
Apr 28, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Logo
653 people viewed this question
Top Whirlpool Dehumidifiers Experts
Marvin
Marvin
Mike
Tim Venetis
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
