Question about Hotpoint Dishwashers
Hi, my Hotpoint aquarius SDW60 has blown my main fuse, and is overheating giving a burning smell, 2x lights flashing on the front?
Anonymous
    Sergeant:
  • 256 Answers
There is probably a short circuit on the appliance, or a component such as the motor or timer/control board is defective. Contact an appliance service company.
Posted on Feb 22, 2010
Testimonial: "Thanks for that, will do!"
I have an hotpoint sdw60 dish washer that is flashing 2 yellow lights, these are numbers 5 and 7 (fast and dry 40c) and (delicate 50c) can anybody tell me what this means.thankyou
Hotpoint Indesit dishwasher flashing lights fault error codes ...
? 15:08
www.youtube.com/watch?v=FRLbrBPHcnE
May 3, 2015 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/hotpoint-aquarius-fdm-dishwasher-flashing-lights-and-there-fault-codes ...
Oct 02, 2015 | Hotpoint Dishwashers
Hotpoint wash & dry Aquarius. Hi my washing
how long is it on befor it start burning please is it on the wash side or drying side get back to me ok
Oct 22, 2012 | Washing Machines
My Hotpoint WML540 wont start wash cycle. The door lock clicks 4 or 5 times then the red door lock light flashes.
This sound like the main control board has blown and this is due to the motor shorting out, if you isolate the power supply and remove the control panel you will be able to remove the pcb/module and inspect it for signs of burning or split tracks if you find this is the case usually it is cheaper to replace the machine than purchase a pcb and motor.
Regards
Ian
Apr 20, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius extra wma40 - door locked light is flashing and want lock. also before this happened a sound from the machine like an explosion which blew out fuse in the house. please advice
Hi.
I suspect that the top control board has blown , this happens when the brushes wear out in the motor, and short circuit the motor armature, which in turn blows the control board.
Either way it is likely to be an expensive repair, my advice to you would be to buy a new washer if it is more than 5 years old.
I know from experience that this is the most likely course.
Nov 13, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Dec 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius SDW60 is tripping the mains power
is the circuit protected by an rcd/rcbo or a standard mcb as this may be a neutral to earth fault/insulation breaking down...try and get the machine portable appliance tested
Sep 05, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius SDW60 Dishwasher
i have had this dishwasher sdw60 for 18 months and it just keeps beeping, i have cleaned it ,turned it off at the mains it just dont wont to work. please help.
Aug 22, 2009 | Hotpoint 24 in. FDW60 Free-standing...
I have a hotpoint aquarius sdw60 with the eco 45 light flashing fast and will not reset I have tried turning off the power I have stripped the pump this was clear. then reinstalled it but it is still same
I have a Hotpoint Aquarius SDW 60 The delay 3hr &12hr lights are flashing at the same time. Machine won't start. If the door is slamed shut. It get stuck on the Fast & Prewash 40 degree cycle. and stays there.
Jul 13, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius Extra washine machine. Won't start..
hi there the pcb behind the control panel is blown this is due to the carbons running low
Nov 03, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Overheating smell on hot wash
this may be charred wiring - most likely at the heater. take off the back bottom panel and look at the wiring at the heater
Mar 31, 2007 | Hotpoint Aquarius WD63 Front Load...
Dishwashers Logo
461 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Mike
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
