RESTORING THE FACTORY IMAGE
The Restore Disc that came with your system contains
two utilities:
? The Recovery utility allows you to restore the original
contents of the C: drive.
? The Hard Disk Data Delete utility on this disc is used
to delete all data on your hard disk and prevent it from
being reused. Do not use the Hard Disk Data Delete
utility unless you are absolutely certain that you want
to erase your entire hard disk, including all partitions.
BOOT Priority Change
Before restoring an image, you must first verify that your
system is set up to boot from the DVD drive. To verify/
change the boot-up priority (rather than booting-up
from the hard drive or an external floppy disk drive),
perform the following steps:
1. Start your system and press the [F2] key when the
Fujitsu logo appears. You will enter the BIOS Setup
Utility.
2. Using the arrow keys, go to the Boot menu.
3. Arrow down to the Boot Device Priority submenu.
Press [Enter].
4. If "Optical Media Drive" or "CD-ROM Drive" is not
at the top of the list, arrow down to the drive in the
list, and press the space bar (or the + key) to move it
to the top of the list. (The system attempts to boot
from the devices in the order in which they are
listed.). Note that the BIOS for some systems will
indicate "CD-ROM Drive", even when a DVD drive
is connected. Then put in DVD restore disc that came with the computer and follow its instructions.
• This disc can only be used with the system with which it was purchased.
Fujitsu IT and Business Services IT Consulting IT and Business Solutions
