Question about Vestax Vci 100 Midi Controller
Vestax vcm 100 driver traktor pro
I have a second hand vestax vcm 100. I already have traktor pro. When I want to select the vestax midi controller in trakor at devices, the vestax is not there. Do I need some kind of driver?
Posted by theprie on
voodoobass
  • 3 Answers
Hi, you need to go here:
http://help.vestax.co.jp/en/detail.php?id=80&id_page_url=56&cate=0
and download the .tks file for your version of Traktor. Suggest you save it to the Traktor program directory.
Then within Traktor in the controller settings section, load the .tks file, save and you're good to go. Obviously you can tweak the configuration as much as you like once it's loaded. Suggest you always keep a backup of the original.
Posted on Mar 22, 2010
Anonymous
    New Friend:
  • 20 Answers
First go to your native instruments service center and make sure you have installed the latest traktor pro update. After that connect the VCI 100 to you computer and start traktor. Than go the controller manager in the preferences window. Select the VCI100 as device and set the in port to all midi. Of your VCI100 does not show up switch USB ports. Try all the USB ports until your VCI shows. If this does not work go to your hardware center, I asume you work on windows, and scroll down to USB devices. Your VCI should be listed there. If it isn't it would be listed as general usb device. Then right click to solve the driver problem in windows.
Unfortunately there are no single drivers available for the VCI. The device should work with just connecting it to your computer.
Posted on Mar 10, 2010
Vestax typhoon controller jog wheel stays red
look at the back of your deck there shold be two little nobs that say touch sensor level turn it down to min or at least dont have them all the way up
Jun 11, 2012 | Vestax Typhoon USB DJ MIDI Controller with...
I recently upgraded my operating system (to Mac OSX 10.6) and now my VCI-100 won't show up as a device. Any advice on how to resolve this?
Here is an online manual, Can't download it, though. Hope it helps.
http://www.manualslib.com/manual/399951/Vestax-Vci-100.html
Mar 10, 2012 | Vestax Vci 100 Midi Controller
Hello i cant seem to find a driver for my vestax vci 100 for my macbook 10.6.3 plz help thankyou
well what software are you using. They is plug n play capable w VDJ and the drivers if there any should be on vestax's site or on a disk that came w the software. and if you need mappings for it meaning to your controller works with tratoktor www.djtechtools.com like i said you might not need a driver for it but let me know
May 24, 2011 | Vestax Vci 100 Midi Controller
How do I get the Vestax vci mk2 to work on a sony vaio notebook? It seems that people have problems with the sony vaio laptop picking up the controller. On the vestax website it says that the problem is...
There probably is a conflict with the camera hardware and or driver. Your best help may be on those Vestax forums. You could try removing the camera drivers in the Sony... but it may be a hardware conflict that may have no solution.
Mar 07, 2011 | Vestax Vci 100 Midi Controller
I just installed my vestax typhoon and the drivers. everything seems to be running fine but i can only listen through the headphones plugged into the controller. no sound comes through my laptop speakers....
Make sure the Windows computer has the audio output selected to use the computers output hardware.
In the control panel, under "sounds and devices" pane, VOICE tab, that the Voice playback window shows your COMPUTER's audio system AND then check the volume is turned up by clicking the Volume button right under that same window. Now do the same under the AUDIO tab at the sounds and devices pane.
Feb 11, 2011 | Vestax Typhoon USB DJ MIDI Controller with...
I just bought the Vestax typhoon but everytime I go to the setup wizard in Traktor it says controller not connected and I'm not able to use the controller
Make sure you have loaded the right driver for this and the operating system is allowed. Vista and later sometimes won't work unless you have compatible drivers.
Jan 04, 2011 | Vestax Typhoon USB DJ MIDI Controller with...
Where can i send my vci 100 to get repaired ? neil mk
You don't give your location so start here:http://www.vestax.com/v/ Try contacting the two distributors here:http://www.vestax.com/v/wtbuy/ .
Aug 25, 2010 | Vestax Vci 100 Midi Controller
Vestax Vci 100 Midi Controller Logo
2,472 people viewed this question
Top Vestax Music Experts
Jeffrey Turcotte
Jeffrey Turcotte
rhodesworks
Lawrence Oravetz
Are you a Vestax Music Expert? Answer questions, earn points and help others
