Computers & Internet Logo
Posted on Feb 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen goes blank randomly during use while VGA signal present LED on front panel remains green. Possible backlight issue.
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Feb 22, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366042
Points
33650
Yes, it can be inverter back lights circuits issue or bad caps in the power supply, worst case will be the lamps. Open it up and post back what you see inside so we can guide you further, see failed monitrs due to bad caps: http://s807.photobucket.com/home/budm/allalbums
2helpful
AKAI LCT37Z6TA TV Issues
Sounds like the main board as it has all control and signal processing on it.
Boot up issues
it is possible a VGA card damage.
1helpful
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
With VGA input the screen randomly flashes on and off
power control chip of the VGA input screen is not controling the input settings
1800FP green LED is on, screen is black
power pack has issues could be a chip on the power pack or some capacitors on the power pack. the power pack supplies power to the inverter.
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Dell 1800FP, no signal found (analog). Green LED on, get message
check if your signal cable is properly connected to your system unit and make sure that non of the pins of your signal cable is broken.if any of the pins are broken,try and change the whole signal cable and re-connect it again
after following the above instruction,reboot your computer
thank you for contacting as with your problems,you are always welcomed
The monitor screen blank / black and power on off switch flashes
You could check the VGA cable from the replicator to the monitor, but a problem with that will usually cause a "NO SIGNAL" message to appear. So your issue seems to lie within the monitor. It could be that the backlight has quit. That can be determined by booting the laptop and connecting it to the replicator, or perhaps to the monitor directly, and observe the screen using a good flashlight, place the flashlight flush on the screen in an area where you would expect to see an icon or some recognizable image. Look closely to see if the image can be seen. If the image is there, then the screen is ok but the backlight is out. The problem is usually the inverter. A reputable shop might be able to replace that.
When i turn my CRT on, after a few seconds my screen goes blank, then displays again, while this thing is happening, i can hear something switching... power led is on(green)... even when the display goes...
It sounds to me that the monitors power supply is dying. I would replace it with a different monitor as soon as possible. I would consider this a dangerous situation, and a possible fire hazard.
Thanks for using FixYa,
Hope this helps,
Eric
Grand Canyon Tech
Grand Canyon Tech
