Question about Gaggia Titanium Espresso Machine
Ventilate message When I was doing routine descaling, it stopped and gave me a "ventilate" message. The hot water flows freely.
Posted by gnvoris on
ifr500
  • Gaggia Expert
  • 109 Answers
Press the hot water button and allow water to flow from the steam arm until ventilate disappears and warming up appears on the display.
Ventilate after descale is normal.
Posted on Feb 24, 2010
My Gaggia Titanium has an ventilate problem when it is stil cold. After starting up, autotest and running pump, it appears whit message ventilate. It takes a long time steaming or hot water after the
The ventilate sign appears as an error message to tell operator that the flow of water is reduced. I can tell that the machine has not been descaled or was descaled using unscrupulous products that are labeled as descaler but they are not.
Because the sign disappears at this time after flushing water through the steam pipe, the flow restores the sensing that water is flowing normal. This "apparent restoration" of water flow is without any back pressure. The espresso function is restored for limited use.
This error code if not corrected immediately, it will not disappear and not allow any function even after flushing water manually.
The flow meter registers the quantitative flow of water as programmed for espresso.
Please descale the machine as soon as possible. before the 'Ventilate' error message stops all functions.
This is a well designed machine. Needs more attention to maintenance.
You may use the link to order our Best descaler.
Services Unlimited Inc Parts Guru
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 19, 2014 | Gaggia Titanium Espresso Machine
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia Titanium - can't get it to move beyond 'Ventilate.' This started as a problem with extremely slow coffee output. We've been good about de-scaling but brought it into a repair place who cleaned it...
Select "Hot Water" and open the steam valve. Let it pump water out the steamer for awhile. It usually clears right away but may need to pump a lot of water to clear the error.
If you aren't able to get any water coming out the steam nozzle, you may need to prime the pump with the little squeezy tool they gave you with the machine - or you can use a turkey baster. Mainly you are trying to get water up into the pump to prime it (get the air out of the pump) so it can pump water instead air.
Oct 09, 2010 | Gaggia Titanium Espresso Machine
Descaling cycle will not run
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Jun 12, 2010 | Gaggia Titanium Espresso Machine
Will no ventilate,no hot water will not descale
HI
You have a calcified solenoid valve for you steam and hot water. It either case it has to be taken apart (which is not easy) or replaced. This is why we need to descale more often. Solenoids work on close tolerance and any scale on them will cause the to stick and not activate. Now they will not open to allow water to flow. So now you can't ventilate. Sorry
Oct 17, 2009 | Saeco Royal Digital Plus Coffee...
Espresso does not make
Remove the portafilter and press the brew button, if the water flows from the head with a nice flow then the problem is with the grind (too fine), or the coffee has been Tamp too hard.
If water barely flows when you press the button then try backwashing the machine and removing the shower screen to clean it.
May 19, 2009 | Coffee Makers & Espresso Machines
Solis Palazzo - dreaded ventilate problem
Hi
Your machine is still in the descale mode. You haven't finished. If you have run the descaler through, the water is ermpty the pump will still keep going until it stop on its own. If it doesn't stop on its own, the computer thinks its still in the descale mode. remove the water tank and turn the machine back on. The pump will run and then make a lot of noise, then stop. This can take up to 5 minutes. Let it run until it stops. You will get blinking lights on the panel. Put the water tank back on and close the steam knob then open it again. The pump will start the rinse mode. Let it stop on its own. Computer can't see that you ran a whole tank of water, but it can see when the flow meter stops that there is no water left. If you have already rinsed the machine start the pump flowing and just lift the tank off. When the pumps stops the rinse cycle the descale light will be gone but you will have the heater light blinking and the water light steady. Put the tank back on and close the steam valve then open it again. This will clear the water light and the machine will start to heat again.
Apr 15, 2009 | Saeco Incanto Classic Espresso Machine
2 messages: descale, and ventilate plus no hot water only steam
descale you need to use special descaler not vinegar vinegar is not strong enought and remove calcium in little piece that might block elsewhere descaler melt calcium 1 part water 1 part descaler fill the water container start machine open side valve for few second turn it off wait 15 minute repeat untill empty after rince very good that stuff is corosif go in thr menue reset the descaler mode and voila !
THANKS FOR USING FIXYA
FROM MONTREAL
CANADA PIERRE
Feb 18, 2008 | Saeco Royal Professional Espresso Machine
I am getting an error message that says VENTILATE
Try draining the machine. Page 37 of the user manual, Drainage. Place cup under the steam/hot water tube, turn knob clockwise around to 9. If the pump is ok, it will start automatically and start filling the cup. Drain about 1/2 cup of hot water and return knob counterclockwise to start position. If the flow meter is not damaged, the Ventilate message should be gone.
Nov 07, 2007 | Saeco Royal Exclusive 30153 Espresso...
Stuck on Ventilation
I went through 3 machines (both Gaggia and Saeco--both have the same Rapid Steam system), hours of searching the Internet, and phone conversations with support(?) staff before I came up with what seems to be good options for both fixing the problem and then preventing it from being a problem again.
The Fix. Fixing the problem works better with two people, so I will refer to person 1 (P1) and person 2 (P2). To fix the problem: 1) P1 uses either a turkey baster or the small plastic (and leaky) pump packaged with the machine; 2) while the readout says "ventilate", P2 pushes the hot water button, then turns the machine off and removes the water tank; 3) P1 fills the plastic pump (or baster) with water and inserts it into the water intake valve (as best as you can, it doesn't fit perfectly); 4) P2 then turns the machine on and opens the steam wand while P1 pushes water into the intake using the plastic pump or baster; 5) as soon as P1 is finished, P2 turns off the steam valve. Repeat steps 3) through 5) until the machine has accepted 4-5 good pumps of water. If you get the "fill watertank" message, you must begin the entire process over again (if you get the "fill watertank" message every time, just keep following the process until you get the machine to accept 4-5 good pumps of water); 6) turn the machine off and reseat the water tank. 7) Turn the machine on, press the hot water button, and open the steam valve. It may take a minute, but you should finally get water. Run it until it becomes a steady stream, and then some more...about 8 ounces worth. I have found that this process doesn't always work if the machine is hot. When it's hot, it sometimes won't accept any water into the intake valve.
Prevention. To prevent the problem, I have been successful (so far) by: 1) after steaming milk, I push the hot water button and run hot water through the wand until it is a steady stream, and then about 4 oz more. 2) I always steam the milk first, then run hot water through the wand, and then make the espresso. 2) I always run water through the wand after making coffee.
This seems like a lot of steps, but it really doesn't take that long once it's part of your routine. I've been successful with this process for the last several day and before that, I was getting the ventilate message every time I tried to steam milk. I'm hoping it continues to work! It's really a shame that the technical staff have not come up with a better solution or, at the least, addressed the problems people are currently experiencing. When I called Saeco, they told me they didn't know why it as happening!
Nov 01, 2007 | Saeco Incanto Classic Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
2,494 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
