Question about Apple iPhone (16 GB) Smartphone
IPhone charging problem
My iphone doesnt charge and ive read all of the posts about software problems. please help because my iphone doesnt have a software problem its jailbroken and its a 2g. its acually not charging cause its at 3 % charge and it wont turn on. i got the battery percentage for 2g cause i jailbroke it. ive tried all of the methods and they havnt worked. PLEASE HELP
5 Related Answers
Anonymous
SOURCE: Apple iPhone Won't Turn On!!!
Does anyone have a real solution. I am a legit owner of an AT&T Iphone with a contract and mine won't turn on after 2 days of use! So obvioulsy it is not because the person unlocked the phone!
Posted on Aug 11, 2008
Anonymous
SOURCE: Restoring iPhone
Turns out it was the SIMM card, not the iPhone - both times.
Posted on Feb 17, 2009
Anonymous
  • 18 Answers
SOURCE: iphone 2g,home button does not working.
Go to http://www.pdasmart.com for your iphone solutions. They work on pretty much everything. They do not charge anything to look at it.
Posted on May 25, 2009
Anonymous
  • 173 Answers
SOURCE: iphone charging problems
I was just anwering another person with the same issue as you. As I was telling him, it is a common issue that I fix 4-5 per week. But it is a very difficult repair. Your main flex cable needs to be inspected and posibily replaced. This cable also has the Microphone, Speaker and bottom charging port copnnected to it. I suggest taking it to a repair shop with iphone specialty. If you are in US you can ship to me if you like. [email protected]
Posted on Jun 24, 2009
Anonymous
  • 8 Answers
SOURCE: Jailbreak iPhone
hi,
Well, this is a known issue. All you have to do is Jailbreak your phone again, without doing a restore.
And that should help.
Thanks.
Posted on Mar 15, 2010
Iphone 5c
Not sure. But dod you check if the charger and the cable are correct? When you insert the charger cable the phone should give a beep, turn on for a few moments and than goes in sleeping mode. If nothing happens, please try another cable and / or an different charger.
Jul 27, 2014 | Apple iPhone Cell Phones
Iphone won't charge unless it is completely powered off
Luckily, there are some tracks you can try to fix it.
iPhone wont charge when turn on
# Check Charging Accessories
# Clean Charging Port
# Hard Reset Your iPhone
# Using iPhone Recovery Mode
# Restore iPhone to Factory Settings
http://www.recoveryiphone.net/article/fix-iphone-wont-charge-when-turn-on.html
try practical methods to fix your problem, and if it still can't get your problem solved, just take it in for service at the nearest Apple Store in your area to get the help of the Apple employee.
Mar 20, 2013 | Apple Iphone 4s latest Model - 32gb -...
Why doesnt my iphone charge when its on but it charges when its off?
This is not the normal behavior of iPhone. iPhone should charge regardless if it's ON or OFF.
What's happening is that the battery is being by-passed when charging it while the phone is ON. There could be a possibility that the battery could be faulty or there are components that needs to be replaced.
If the phone is still under the warranty, kindly contact the manufacturer and have them repair or replace the battery for free.
Good luck and have a great day!
Jan 05, 2010 | Apple iPhone 3G Black Smartphone
Hi there!
There have been some reports of iPhone chargers going bad prematurely.  The test:
  1. Connect your iPhone to your computer via the USB cable.  Does it make a little beeping noise when you connect it, and then charge up?  If so, the issue is not with your iPhone or USB cable.
  2. Next, using that same USB cable, connect it to your iPhone charger.  Do you get the same connection noise and then does it charge up?  If not, the issue is probably with the charger.
Assuming you have a faulty charger, you are still well within your 1 year warranty from Apple.  Visit an Apple store (www.apple.com/retail) Genius Bar (make your reservation online before you go, to avoid waiting around), explain the issue and how you tested it out, and they will almost certainly replace the charger for you at no cost.
Oct 11, 2007 | Apple iPhone Smartphone
Apple iPhone (16 GB) Smartphone Logo
220 people viewed this question
Top Apple Cell Phones Experts
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
B Louis
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
