Please read this if your red descaling light won't turn off: Key is to follow directions. When you fill the tank with water to descale add 500 cc - no more. The machine "knows" that the cycle ends when water runs out. Once water runs out the red light will turn off. Continue with cleaning the tank and running a cleaning cycle. The red light is gone and you are good to go.
SOURCE: red de scaling light won't shut off
Removing the red descaling light is simple.
1. Fill reservoir with half vinegar and half water (no need for the special descaling product from Tassimo).
2. Turn on machine.
3. Insert yellow cleaning disc found in back of machine.
4. This is where most people have the their problem...You must hold the start button for 3 to 5 seconds for the descaling program to start. Both green and red light will flash.
5. Once started, use a large cup to catch the output of water.
6. The machine will cycle through the descaling program in about 30 to 45 minutes. Be paitent!!!
7. Once completed, run many cups of plain water through the system to remove the vinegar taste.
8. Red light problem is solved.
Hope this works for you.
SOURCE: Descale red light, wont go off, and can i use any delcale tabs
Solution: Just refill the water tank with water (no descaling solution) all the way to the "Max Line". Then run the full descaling program again --takes approx. 20 minutes. After the program runs completely you will get the yellow "standby" light on and the red "descaling" light will be off.
Next time you descale, be sure and fill your water tank to the "Max Line" before running the descaling program.
Hint: An incomplete cycle (not full tank) is what makes the red light stay on. In other words, it's staying red to tell you to run a full cycle (beginning with the water tank filled to the "Max Line"). Hope this tip is helpful!
SOURCE: bosch tassimo
SOURCE: descaling your tassimo machine
My Bosch manual is very specific: DO NOT USE VINEGAR! They recommend you use any commercial coffee machine descaler.
CLR recommends itself for the job and the Jellmar website has instructions.
