Question about ASUS NVIDIA GeForce 8800 GTS (512 MB) PCI Express Graphic Card
I have vertical red lines generated by my Nvidia 8800 GTS graphics card
Posted by rob_mitchell on
Naveendra
    Novelist:
    Scholar:
  • 103 Answers
Its a GPU problem.
It can be overcome by doing reflow technique.
You need to do following.
1. Uncover ur PC casing
2. Locate the nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get scrambled display/wavy screen, but wait for 5 minutes.
7. Press reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10. Connect the power supply pin back as it is.
11. Power on ur PC.
thats all.
Removal of fan power, makes the GPU to get high heat, it a reflow technique.
Remember, not to touch the GPU portion (heat sink), as it may be in higher temperature.
Try this, it works most.
Clarifications:
[email protected]
Posted on Jun 05, 2010
  • warriorpoet Mar 31, 2011
    I just got two of the proformance version 8800gts for free from someone that wasn't sure if they worked.. both of them where giving bad red, or blue lines, and then doing mem errors, and rebooting. I tried this fix on each of them.... and it worked on both of them! first on one, then on the other.. my second one is cooling on the table right now and so far so good! I'll try sli tomarrow and see if they work together.. but they are a huge upgrade from my 8600gt cards. Thanks for the fix!!!!
Blue vertical lines
Hi, I am sorry you are having issues with your graphics card.
Yes the oven trick does work but it is only temporary and you will have to do that process over and over until the card just all out quits responding. Once a GPU begins to display multicolored or blue lines across the monitor its time to put it out to pasture so to speak.
Aug 31, 2013 | MSI NX8800GTS-T2D512E Geforce 8800 GTS...
GeForce 8800 GTS Manual
Here is a generic manual for 8800 series cards.
http://www.nvidia.com/content/3dvision/docs/GeForce_3DVision_QSG_Booklet_NoBarcode_Dec08_Screen.pdf
If this is not what you wanted, please provide the manufacturer of your card, (and perhaps the problem you are having as well).
You may not find the manual very helpful depending on what your problem is.
Dec 30, 2011 | Computers & Internet
Nvidia 8800 gts graphics card willnot work properly since upgrading tiwindows 7
hi makemtakem
please check as you might be using the WDM or the windows drivers included in the Windows 7 installation. You may want to try to upgrade to the latest drivers found on the nvidia website itself. www.nvidia.com some features for the card specially gaming features are not fully functional with just the WDM drivers since this is already outdated.
hope this helps, please let me know
janc30
Feb 16, 2011 | HP Pavilion HDX9000 Notebook
What is the best pc graphics card? for blu-ray and 3d.
This is the list of Nvidia Gfx cards that can support blu-ray and 3dvision
NVIDIA GeForce Graphics Cards
GeForce 400/300 Series GeForce 200/100 Series GeForce 9 Series GeForce 8 Series 3D Gaming Desktop
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 460
GeForce GT 340
GeForce GT 330
GeForce GT 320 Desktop
GeForce GTX 295
GeForce GTX 285
GeForce GTX 280
GeForce GTX 275
GeForce GTX 260
GeForce GTS 250
GeForce GTS 240
GeForce GT 140 Desktop
GeForce 9800 GX2
GeForce 9800 GTX+
GeForce 9800 GTX
GeForce 9800 GT
GeForce 9600 GT Desktop
GeForce 8800 Ultra
GeForce 8800 GTX
GeForce 8800 GTS
GeForce 8800 GT 3D Applications Desktop
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 460
GeForce GT 340
GeForce GT 330
GeForce GTX 295
GeForce GTX 285
GeForce GTX 280
GeForce GTX 275
GeForce GTX 260
GeForce GTS 250
GeForce GTS 240
GeForce 9800 GX2
GeForce 9800 GTX+
GeForce 9800 GTX
GeForce 9800 GT
GeForce 8800 Ultra
GeForce 8800 GTX
GeForce 8800 GTS
GeForce 8800 GT 3D Pictures Desktop
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 460
All GeForce 300 series Desktop
All GeForce 200 series Desktop
All GeForce 9 series Desktop
All GeForce 8 series Blu-ray 3D playback* Desktop
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 460
GeForce GT 340
GeForce GT 330
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 295**
GeForce GTX 285**
GeForce GTX 280**
GeForce GTX 275**
GeForce GTX 260**
GeForce GT 240 Notebook
GeForce GTS 360M
GeForce GTS 350M
GeForce GT 335M
GeForce GT 330M
GeForce GT 325M
GeForce GT 320M 3D Movie file playback Desktop
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 460
All GeForce 200/100 series Desktop
All GeForce 8 series * Blu-ray 3D playback requires compatible Blu-ray 3D player software from companies such as CyberLink and Arcsoft. Please continue to check the 3D Vision product home page for more details on Blu-ray 3D support.
** Blu-ray 3D GPU decode acceleration is not supported on these models. Please insure that your CPU is fast enough to handle video decode (a quad-core CPU recommended)-->
And don't know about ati graphic cards which has these features. i'm sure i have given you a satisfactory answer.
For further any help or to thank me you can mail me on my email [email protected]
Aug 08, 2010 | Computers & Internet
Vertical lines on startup. code 43 Adapter display. 8800GTS win 7
check to see your direct x status by typung dxdiag in run and test if they all pass then I would check the card wattage rating and you max power supply load the card may be to much for your power supply
Feb 02, 2010 | Leadtek GeForceĀ® 8800 GTS, (320 MB) PCI...
Can foxconn g33M02 handle 500watt psu? and what nvidia geforce 8 series will work on my mobo?
Nvidia Geforce 8 is PCI-E Card.
Here are the list. This were all best and good to your MOBO.
bar_specs.jpg Core Clock (MHz) Shader Clock (MHz) Memory Clock (MHz) Memory Amount Memory Interface Memory Bandwidth (GB/sec) Texture Fill Rate (billion/sec) GeForce
8800 Ultra 612 1500 1080 768MB 384-bit 103.7 39.2 GeForce
8800 GTX 575 1350 900 768MB 384-bit 86.4 36.8 GeForce
8800 GTS 500 1200 800 640MB or
320MB 320-bit 64 24 GeForce
8800 GTS 512MB3 650 1625 970 512MB 256-bit 64 41.6 GeForce
8800 GT
600 1500 900 512MB 256-bit 57.6 33.6 GeForce
8800 GS 550 1375 800 384MB 192-bit 38.4 26.4 GeForce
8600 GTS 675 1450 1000 256MB 128-bit 32 10.8 GeForce
8600 GT 540 1190 700 256MB 128-bit 22.4 8.64 GeForce
8500 GT 450 900 400 256MB 128-bit 12.8 3.6 GeForce
8400 GS 450 900 400 256MB 64-bit 6.4 3.6
  • Full support for both Microsoft® DirectX 10 and DirectX 9 for unparalleled levels of graphics realism and performance
  • NVIDIA PureVideo™ HD2 technology provides unsurpassed Blu-ray and HD DVD movie picture quality
  • NVIDIA 8 Series graphics processors are essential for accelerating the best Microsoft® Windows Vista™ experience
Here is the link for more details about GeForce 8 series:
www.yboyandrei.com/geforce8
Hope i help a lot and give some ideas.
If i am helpful, please rate me.
Thank you. Good luck!
Yboyandrei
Aug 18, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Nvidia geforce 8800 gts code 43 due to vista home premium
Well if you installed the correct drivers for your video card and have the proper power supply requirements, then the vertical lines you're getting most likely indicate that your video card is bad.
Try it in another computer if available, or get another video card.
Jun 19, 2009 | PNY XLR8 NVIDIA GeForce 8800 GT 512MB...
Trying to load call of duty 5 world at war . with g force 8800
It will say on the box it was packaged in what the minimum requirements are for the game....
Here is from a site i found....
Processor: AMD 64 3200+/Intel Pentium 4 3.0GHz or better
Memory: 8 GB free hard-drive space, 512MB RAM (XP)/1GB RAM (Vista)
Graphics: Shader 3.0 or better, 256MB Nvidia GeForce 6600GT/ATI Radeon 1600XT or better
http://www.nvidia.com/page/geforce_8800.html
link for your line of graphics cards.
You have not given the entire model # so it is unclear if your card is sufficient, however it does say GeForce 6600GT or better - which yours is
Dec 22, 2008 | Nvidia GeForce 8800 GT 512MB Graphic Card
ASUS NVIDIA GeForce 8800 GTS (512 MB) PCI Express Graphic Card Logo
Top ASUS Computers & Internet Experts
Roy May
Michael Thomas
Michael Thomas
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
