Carrier split system powers down and the green power light flashes 5 times . it is not cooling at all.
Posted by matts293 on
Anonymous
    New Friend:
  • 66 Answers
Check,and clean the condenser coil . If it is dirty, system cannot breathe.
Posted on Feb 22, 2010
My 1 ton carrier split ac 15 minits running after stop and blinking green light 4 times.whats the problem ?
This problem is outdoor unit issue. Blinking 4 times in carrier highwall unit means Compressor drive malfunction. Possible cause are the following:- Stuck up or grounded compressor.- Magnetic contractor in outdoor unit is defective or indoor unit relay supplying outdoor unit is defective.- No power supply going to outdoor unit
Sep 22, 2018 | Carrier Heating & Cooling
My carrier split ac trip after some time and green light blinking contsly
If this is a ductless split call a tech! The ductless split systems can be a troublesome unit to diagnose. A few things to try. Clean air filters and ensure coil behind is clean. And build up or debris on blower wheel (indoor fan blades) will cause unit to fault. Turn off power at breaker or disconnect and clean (with water hose and medium pressure) the outdoor coil. Be sure you will not damage outdoor coils fins with too much water pressure. Turn power on. If this simple service don't do it again, call a tech! Be sure to ask if they have someone who is experienced with mini split systems and be patient. Even the best technician will need to call carrier for tech support.
Jun 04, 2015 | Carrier Heating & Cooling
Error flashing light on Totaline split unit air condintioner
You out door unit is not receiving power adequately. Most of these kind of issues are power related. Eg fluctuations, power unit strength, stabiliser problem or could be an issue with the supply from your mains. 12_1_2015_11_05_14_am.png
Jan 28, 2014 | Heating & Cooling
Not cooling and shutting off, indicator light flashes
the outdoor indictor light on my lg split comes on after some minutes on the one inside and the cooling has reduced please can any1 tell me what the problem is
Jan 18, 2013 | LG LSC121PMA Split System Air Conditioner
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Mar 10, 2010 | Carrier Heating & Cooling
I have a Carrier 42G150H indoor unit for a split system and it has a fault. The green light on the front panel flases 5 times and then there is a delay and then it flashes 5 times...and so on.
Look on the back of the panel where the green light is located. You will need to remove the bottom panel of the furnace and on the back of the panel you removed there should be a breakdown of the codes as to what the flashing green lights mean. If the code list isn't there you should be able to obtain the code list online if not try to call a a/c company to see if they have a code list .
Good luck hope this helped you
Dave
Feb 25, 2010 | Carrier 38CKC042 Air Conditioner
POWER LIGHT FLASHES 5 TIMES CARRIER SPLIT SYSTEM 42PI00H
carrier split ac blinking 5 times & stop the unit
Sep 03, 2009 | Carrier Heating & Cooling
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
