Re: When I pulled the lint trap out there was much on
If it is a top lint filter take the lint filter out,turn dryer on,put your hand in it and you should feel a stong stuckion,if not remove the back panel and the 2 lint filter screws and check for clog-mike
There is no lint trap. There is a coin catcher on the pump. The design of the wash action on a front loader is such there is less lint than on standard machines. One of the bennies of the design. Eric
make sure that when you replace your filter that there is no obstruction in the filter thread(small stone), i have had many problems with this,if the drain light keeps comming on then check the waste pipe stand.
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Remove the humidity sensor by taking off the lint trap inside the door. There are 4 philips head screws then the sensor is attached with 2 wire connectors. Pull these off then reattach and reassemble the lint trap. I did this on mine and it works fine now. There must have been some corrosion or a poor connection on one of these wires.
Set top tension at 4 for most purposes on this model.
Are you certain that it is threaded correctly and not trapped or double wound on the take up arm or elsewhere ??
Do try a re-thread just to be sure.
Bobbin case may have thread or lint jammed in the spring allowing eased tension below and presenting as increase above.
Check for and clean any lint trapped in the bobbin case.....anatomy of Janome Bobbin Case:
TOP LOADER: Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
Luckily, dryers are light. Best thing to do is pull it out until you can remove the back cover. (unplug it first) Then vacuum and clean all the dust and lint you can. This should be a yearly thing at least anyway. Replace the back plug it in and slid it back. I do mine every 6 months or so.
its not too hard to get out. you will need a #2 phillips screwdriver and or a 1/4" socket driver remove lint trap remove 2 screws at lint trap unplug unilt open the top (2 clips between lid and front panel in the crack, push them with a butter knife or putty knife to release top) opens like a hood pull out dryer and pull off rear panel on the left hand side there is a metal duct like thing lol that leads to the lint trap at the top. there should be 4 screws at the bottom where it gets round. remove them, and wiggle the duct open. your pen should be there..
How can I clean the lint out?
