Question about Audiovox FPE3206 32 in. LCD Television
MY TV TURNS ON BUT NO PICTURE OR SOUND I HAVE A AUDIOVOX FPE3206 MODEL
Anonymous
    New Friend:
  • 39 Answers
You could have bad capacitors in power supply.You can probably see the they normaly have flat top.If top is round like a bubble it is bad.This is common problem with flat panel lcd tv and monitors
Posted on Feb 22, 2010
Tv screen blacked out. no picture or sound. powers up blue led lights no remote response or menu options
hello,it's the I.C that got bad,so all you need to do is just to replace the bad one with a new one to have your TV powering on as normal,
please kindly rate this solution if it's helpful,
take care.
4helpful
No screen
sound no picture
its the invertor board controls the backlighting
4helpful
2answers
Tv power comes on but no picture th name Audiovox
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
1helpful
2answers
I have power, but no sound or picture
djchillsync is correct - the power supply on these are really poorly engineered and made. Audiovox is trying very hard to ruin thier reputation by putting ou **** like these sets. Contact them for warranty repairs, you may not get them paid for but you'll be directed to someone that knows what they are doing.
Audiovox fpe2705 inverter board replacement
You need to verify first that you do have 24vdc feeding the inverter boards, if you do have 24vdc then we can be sure it is the inverter boards. The inverter board will have very small surface mounted fuses, check for that also.
Olevia tv start on audio on, no picture
that is a sign of a possible power problem it may be fixed by exchanging the powersupply or some other iternal panel the best way to troubleshoot this is by getting a service manual if your inclined electronically. basically voltage checks and identified fualty circut or board
this happens with lcd and plasma panels the circut may go bad and loss the proper voltage capacities and it cuases the tv to go into a safety circut like this.
have it serviced or check by a qualified lcd and plasma shop they may have the parts you need for it.
goodluck hope this helps.
3helpful
Audiovox FPE3206 - Power Light is Blue/ON but Screen is BLACK
I had the same problem, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
2answers
Audiovox FPE3206 32 in. LCD Television Logo
Top Audiovox Televison & Video Experts
Ekse
Raj Patel
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
