Hi there
This board is also known as K8MM-V.
If you go here: Support For K8MM
Then you will find four tabs toward the bottom of the page, the second of which says Drivers. Clicking on this will give you a box further down which is a drop down menu to select your Operating System. Once you have done this there will be a list of all the drivers for this board and you can download whichever ones you want. You should note that this is quite an old board and it does not appear to support any OS above Vista 64bit as there are no drivers for Windows 7 or higher. Also with only 2Gb RAM maximum supported (according to the manual) I doubt its capability to run Win 7 or higher.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Please select your windows system, click on zip file for download. Unzip the file when downloaded, before you install the driver. Not all windows system is supported, such as windows 7. Other drivers can be downloaded here: http://www.viaarena.com/drivers.aspx By selecting your windows system.
Your board is actaully listed as a model K8mm-V on the MSI website. Here is a link to the MSI page with the correct drivers for your board. These will work for Version 1 or 2 boards:
I've tried to find your driver but without results.. :/
better try some professional tool like this one: Driver Update Software for XP Vista 7 8
used it many times, and it's awesome.
wish you best of luck
Brian
