This can be memory, CPU, Hard drive, or graphics card, or overheating.
To check the memory, hdd, and cpu you can download the ultimate boot cd UBCD Burn it to a disc then boot to it. Use the utilities on it to test your components.
To check and track your temps you can download HWMonitor keep this running until it crashes. Once it does, reboot then open it again. The program will show you the max that the cpu and gpu reached in temp. gpu ovr 60C is usually starting to overheat. CPU over 50-60C (unless its a core 2 duo or quad then its 80C) is overheating.
To help solve overheating buy a cooling pad and have the thermal paste/pads replaced on the cpu and gpu.
If the problem persists then there is a big possibility that your gpu is heating up to much and the motherboard is starting to lose the solder joints to it.
