Microsoft Windows XP Media Center Edition 2005 for PC Logo
Anonymous Posted on Feb 22, 2010
Media center does not work on my windows xp - Microsoft Windows XP Media Center Edition 2005 for PC
  • Anonymous Feb 22, 2010
    Al my windows xp media center edition is work perfect.
    My only problem is with the media center.
    It is not working.
    Cam you give any idea?
Jax Planet
Level 2:
  • Expert 923 Answers
  • Posted on Feb 22, 2010
Jax Planet
Expert
Level 2:
Answers
923
Questions
0
Helped
255853
Points
140
Windows XP MCE is an operating system not a program.
It cannot be install on any version of Windows as it is a version of Windows itself.
You must replace the version of XP you are using with MCE.
The easiest solution is to add a second hard drive, boot to the MCE disk and instruct it to install a new copy of Windows on the second drive. This will allow you to start your computer with either operating system. It is called dual-booting. It is a great way to migrate from one version of Windows to another.
You can learn more about XP versions here: http://en.wikipedia.org/wiki/Windows_XP_editions
I hope this helps.
  • Jax Planet
    Jax Planet Feb 22, 2010
    Just read your comment.
    Insert the MCE disk and it should automatically play.
    The menu should give you an option to add or remove features.
    If adding or repairing Media Center doesn't work then uninstall it, restart and install it again.
    Make sure you download all Media Center updates from Microsoft Update.
    If this doesn't help, can you provide any error messages.
    Additional details would also help like: "Does it even open the Media Center window?"
Anonymous
Level 3:
  • Master 11,896 Answers
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3734621
Points
36074
You should reinstall it using the installation cd because there is no downloads on the net for this.
    Ok. To watch videos on your computer, you will need to make a new main window screen file. Rename it videos.
    Then transfer or copy any video files into this folder.
    You can check any settings with the player to automatically play videos and pictures. You can suggest the folder from which the player reads from.
3 Related Answers
Anonymous
  • 38 Answers
  • Posted on Dec 12, 2008
SOURCE: media center receiver service error
The only usefull solution i have found is running mcerepair from this site
http://blogs.msdn.com/peterrosser/archive/2005/10/21/483723.aspx
Its from the microsoft developer network so while not being official it is from someone at microsoft
alternativly you could run "sfc /scannow" from commandline or the start > run dialog, this will return all windows system files to their original versions, it might solve your issue
hope you find this helpfull
Anonymous
  • Posted on Dec 25, 2008
SOURCE: copy cd to windows xp media center library
model no compaq c700
sound driver download
Anonymous
  • 33 Answers
  • Posted on May 30, 2010
SOURCE: need product key
BH6K8-MF4YH-PD6B3-FDJ4G-RGV8B
2answers
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
We have windows xp media center 2005 purchased in 2006-7 and I wasn't paying attention to our Help and Solution page until one day I saw that it said the Professional not the Media Center how can I change...
Hi There,
Windows Media Center Edition is exactly that; an "Edition" of XP Pro. If you go to My Computer and then click on System Properties, you will likely be comforted to see that you indeed have Windows Media Center Edition 2005.
Regards
1helpful
I want to know that "is how many Windows XP version is publish So far"? any one answer detail i know only 2 one is HOME edition and 2nd is Professional " IS it ???? what about Media Center Edition...
to your amasement one answer is 8 versions
Windows XP Starter Edition
This edition is aimed for first-time desktop PC users in developing countries. This edition can only run three applications at once.
Windows XP Home Edition
A version of Windows XP for home users. This edition replaced Windows 9x/ME
Windows XP Home Edition N
This is a special edition of Windows XP Home Edition for the european market
without media player
Windows XP Professional
A version of Windows XP for both businesses and home users. This edition replaced Windows 2000 Professional
Windows XP Professional N
This is a special edition of Windows XP Professional for the european market without media player
A Windows XP version for Media Center PCs with an easy to use interface and remote control support
Windows XP Tablet PC Edition
This is a Windows XP version for Tablet PCs with pen and speech capabilities
Windows XP Professional x86 Edition
This edition is for AMD64/EMT64 64-bit processors
guess you didn't knew that.
nice question and thanks for using fixya.
Please vote if satisfied.
Rebooted Microsoft Windows XP Media Center Edition and now media center gone
Click Start>All Programs>Accessories>Media Center>Media Center. That should get you going again.
Do you not have a Media Center remote for your computer?
Thanks for using Fixya.
Media Center for Window XP, TV don't work.
Try reinstall windows. If this doesn't work you might have a conflict with your tv-tuner
2answers
Windows XP, error message!! Media Center TV don't work now, etc.. Error message pops up all the time!!! After I loaded a RipTiger software, had to unistall but still left with this pop up message!!! Media...
Try going into Control Panel, Add/Remove Programs, click on the Media Center software, if listed, and see if it gives a choice to Change and/or Repair. You'll probably need your Windows CD if/when it prompts for it.
Windows xp media center error occurs when trying to record programs
When that happens you usually need to backup your data, and reinstall the system to fix Windows corrupted files.
Try first doing a system restore to the most recent date before you started having the problem. If system files are damaged this will not help.
The media center is part of the WMC operative system. You can also reinstall media center alone using add remove programs, then Add remove windows components. Often that does not work, and you need to use a Windows MCE setup disk to fix the problem.
2answers
Is protools compactable with windows xp media center
Yes, it is currently supported all the way up to Vista x64. For future reference any Windows XP supported program will work fine with Media Center. Enjoy!
Xbox 360-computer?
To connect the Xbox 360 console to this computer, you must be running Windows XP Service Pack 2, Update Rollup 2 for Windows XP Media Center Edition 2005, or Windows Vista.
To obtain your setup package or instructions for connecting your Xbox 360, select the version of Windows installed on this computer from the following list.
To determine the version of Windows XP Media Center Edition that you are running, follow these steps:
  1. Start Media Center.
  2. On the Settings menu, click General.
  3. Scroll down, and then click About Media Center.
  4. Click Software Version
    The version number of Media Center you are running is displayed.
To determine the version of Windows XP that you are running, follow these steps:
  1. On the Start menu, right-click My Computer, and then click Properties.
  2. On the General tab, under System, look for the version of Windows that you are running.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
