Remove cover from air con wall unit
How to remove plastic cover from machine as I have a dead mouse inside. I have removed the 4 screws and need to know where the clips holding cover are located?
  • Anonymous Feb 22, 2010
    Electrolux model ESE 12 HRA there must be lugs holding cover and do not want to force???
    Thank you
  • Anonymous May 11, 2010
    what brand model?
Anonymous
    New Friend:
  • 74 Answers
I went to Electrolux's web site, they don't even mention air conditioners... never seen one myself.
Sorry, other than my assumption that you have a through the wall unit, which implies a box that the unit slides into, doesn't seem to me that any more than four screws would be used to hold the plastic face cover on, try lifting upwards and out from the bottom, in case there are clips, but it may be a little tight just from sitting, good luck.
Posted on Feb 22, 2010
Anonymous
    New Friend:
  • 66 Answers
There are usually 2 wholes on each side and the top. Try lifting the cover at the unit with your fingers(a screwdriver can very easily break your cover) while pressing in on the front of the cover and it pop loose.
How do i open air conditioner to clean filters
A wall unit, split system can be tricky to get. Some filters slip out, some are behind a cover held in by screws, others the complete plastic needs be removed. The filter would be in the section where the air enters the air con.
Other units have the filter behind the return air grill, others a door needs be removed to access the filter rack
May 08, 2015 | Heating & Cooling
Can not print code # 5b00
You must follow the below mentioned steps for help :
1: Remove the Left and Right Covers and the Main Case Unit (main cover).
2: Remove the 4 mounting screws from the Chassis.
3: Remove the Main Unit from the Bottom Case.
4: Turn the Main Unit over (upside down) and place on work surface.
5: Inspect the ASF section of the Main Unit for a gap between the white plastic guide and the Chassis.
Note: The size of the gap varies. Even if the gap is not visible, complete the steps
below.
6: Disconnect the appropriate cables and remove the Logic Board from the Chassis.
7: Loosen (do not remove) the 4 mounting screws (the mounting screws can be found behind the
logic board) on the Chassis.
8: Re-seat the white plastic guide so it sits flush against the Chassis. The tip of the white plastic
guide should sit slightly inside the
mounting screw hole. When seated correctly, the gap will no longer be present.
9: Tighten the 4 mounting screws without
causing the plastic guide to shift.
10: Reassemble the printer and retest it.
Mar 31, 2011 | Office Equipment & Supplies
How can i remove the fan barrel from the head unit to clean it
with care. first remove the screws holding the covers, you will find them behind two or three small caps near the louvers and maybe under the filter cover. Completely remove the plastic face. Remove the screws holding the coil in place. You can only remove the left hand end as the right hand is connected to the pipework. remove the grub screw holding the fan barrel onto the motor shaft. Remove the screws holding the left hand bearing in place. At this point you should be able to withdraw the fan barrel. Take very real care how you handle the coil, for if you kink the pipes your machine will no longer perform without some major surgery. While the unit is dismantled , try cleaning inside the machine, removing dust and mould. Reassemble in reverse order
Mar 05, 2011 | Fujitsu 12C1 Air Conditioner
How to clean pump from fisher & pkal smart drive 708
FIRST - remove plug from wall, then open lid and remove the rubber bungs that the front of the lid sits on, under them is 2 screws, remove them. Lift the complete upper plastic portion and rotate back against the wall. Remove the screw from inside the agitator and remove the agitator completly. Remove the bowl top cover by unclipping it from around the outer edge all the way round, note the spring position for refitting, lift out the bowl top cover and set aside. Remove bowl, can be tricky but it should lift right out. With the bowl removed, remove the large phillips screw from the plastic cover over the pump, with the screw removed, the pump cover will pull out (up) and the pump can be cleaned out.
Make sure that you clean out the channels that the water flows through around the pump impellor. refit the pump cover, ensure the rubber ring is in correct position, and secure with the screw. Reassemble in reverse order.
Test the pump for operation before doing a full load.
Mar 02, 2011 | Fisher and Paykel Fisher & Paykel Washer
Can you explain how to replace the light bulb in my amana oven?the model number AARG7303WW
This worked like a charm ... actually it's easier than you might think. Just a few screws and a few tugs. Give it a shot.. I found a 10W (G4 style ... you'll see the difference when you get to the store) replacement bulb at Home Depot for $6:
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with your fingers or pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
Feb 14, 2010 | KitchenAid KEMC378KSS Electric Double Oven
Dishes on the top tray still come out dirty after washing
This is probably a clogged internal disposal screen. This is a relatively simple procedure that requires 2 tools. There is a screen behind the cutter in the built in disposal unit that gets clogged easily. You may want to order a new part before disassembly. To disassemble: You will need 2 sizes of torqs (star shaped) screw drivers and some patience in reassembly. Be sure to note how things are assembled before removing them. You do not need to unplug the unit to do this as you will be inside the unit and not around any exposed electrical components. Make sure the unit has been off for a while so that the heater element is cool. Remove the top rack by squeezing and sliding the plastic locks upward (on the ends of the rails) Then slide the rack out. Remove the bottom rack turn the center plastic retainer on top of the spray mast cclockwise (opposite most all other screws) and lift out main spray arm remove screw from back center water pipe (oblong flat 2 piece plastic unit on the back wall inside) and rotate it clockwise to release the tabs under the pump cover. Lift above a carefully move out of the way loosen and carefully remove 4 screws from the pump cover/ diverter/ screen unit and lift out exposing the top of the pump and motor housing (usually grey plastic) Locate the screw at the front left of the pump cover that holds down the disposal cover. remove the screw and note which groove the screen is in as well as the side of the screen the blade is on. Replace the blade/ screen unit or clean the old one (under a tap of warm water and with an old tooth brush) and reinstall it. Assembly is reverse of above. Note! Be sure locking tabs are under pump cover as before and you don?t drop the screw for the oblong water pipe!
Feb 12, 2010 | Kenmore Dishwashers
Dishwasher wont push water around inside tub correctly something is blocking water flow to pump i looked for filter could not find
The units diosposal screen is probably clogged.
To disassemble:
  1. Remove the top rack by squeezing and sliding the plastic locks upward (on the ends of the rails) Then slide the rack out.
  2. Remove the bottom rack
  3. turn the center plastic retainer on top of the spray mast cclockwise (opposite most all other screws) and lift out main spray arm
  4. remove screw from back center water pipe (oblong flat 2 piece plastic unit on the back wall inside) and rotate it clockwise to release the tabs under the pump cover. Lift above a carefully move out of the way
  5. loosen and carefully remove 4 screws from the pump cover/ diverter/ screen unit and lift out exposing the top of the pump and motor housing (usually grey plastic)
  6. Locate the screw at the front left of the pump cover that holds down the disposal cover. remove the screw and note which groove the screen is in as well as the side of the screen the blade is on.
  7. Replace the blade/ screen unit or clean the old one (under a tap of warm water and with an old tooth brush) and reinstall it.
  8. Assembly is reverse of above. Note! Be sure locking tabs are under pump cover as before and you don’t drop the screw for the oblong water pipe!
Feb 06, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
1035 ricoh aficio printer with error code 322
Yes, the code is caused by toner getting into the laser unit. The laser unit likely only needs to be cleaned out. To do so, turn the machine of with the red rocker switch on left side of the machine. You will need to remove the front cover and the brown cover behind it. The mechanical counter is plugged into the brown cover so be careful not to damage the wires. The laser unit is the black plastic case you will see behind the brown cover. Be sure to remove the necessary screws and connectors. Be extra careful of the ribbon cable, it kinks easily and the contacts are easily damaged. The Laser unit will slide out, and you can remove the screws holding the top cover on. After removal, clean the interior of the case and mirrors. Do not use any liquid to clean it, preferrabley canned air and a lint free cloth. After cleaning, reassemble, turn the machine back on, and test.
Nov 19, 2009 | Ricoh Aficio 1035 Copier
Want to remove cover of Krups Espressario XP7240
Yes it is tricky but easy once you know it. remove the bean container by pulling off the grind selector knob and removing the only screw.
Then remove the scute for the cleaning tablets. Then remove the two screws that were covered by the scute lid. Remove the water tank. Under the tank remove the two screws.
Then the trick where everyone seems to look for: The facade of aluminum can be moved off. Set the machine on the floor and pull hard upwards at the facade. This comes off (pull hard!) and four screw are uncovered. Remove them and pull then back housing of the machine (remove first the containers/drawers). Now the inner parts are freely accessible. You filter is the white valve connected to the three way valve (white plastic). You remove it by twisting it 15 degrees. Clean the inner parts (valve and spring) from coffee debris.
Feb 01, 2009 | Krups Small Appliances Espresso Machine
2001 Yukon XL Rear Air
all trim is vissible screws or plastic dowel cover with screw under and plastic push clips on the side you cant see so grap a corner and pull
Sep 24, 2008 | 2001 GMC Yukon XL
Heating & Cooling Logo
216 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
