Question about GE 13.7 cu. ft. General Electric Upright Freezer FUF14SUR
Freezer starting to defrost
My upright GE freezer is blowing cold air but the temp. is not freezing. The food is starting to thaw. Do not have a control inside.
Posted by wandagdurham on
D. Floyd Kolb
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 02, 2010
Not cool enough to freeze the food
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps.
Regards.
May 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer not freezing .. It's cold..
I hope this helps........
Take care.
Apr 12, 2011 | Northland Panel Ready Upright Built In...
Imperial commercial upright. Top shelf is icing and frezzing bottom is not freezing.
Good luck.
Apr 12, 2011 | Freezers
Freezer blowing cool air, but not freezing.
Hello there:
first make sure that the back of the unit is clear of any dirt or obstructions
also make sure that the food is not stacked up so high that the air cannot circulate also you may want to check the temperature setting if the unit does not respond to a lower setting your refrigerant level may be low or than you will have to have the temperature controle thermistor serviced or replaced
Sep 15, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a 4yr old 13.7 cubic upright frigidare freezer. Running all the time, I defrosted it recently (only minimal frost/ice on base behind basket) after noting top shelf warmer than others and food...
Hi, Put a thermometer in the freezer and see if it gets down to 0 to 5 above zero. If it is not getting that cold, something is wrong. If you had frost building up behind the rear panel, there is a defrost problem.
Please let me know the temperature and I can assist you further.
Vic
Jun 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer Not Freezing Food
there is a circulation fan and also a vent. Either the fan is blowing, or there is a cloged vent.
Feb 11, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
GE 13.7 cu. ft. General Electric Upright Freezer FUF14SUR Logo
175 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Are you a GE Freezer Expert? Answer questions, earn points and help others
