Question about LG Vu CU920 Cellular Phone
Lg vu...chrages and says battery full in a few mins, then has full bars...last all day for txting..but dies within 2 mins of talking
Posted by joeshmoe863 on
Anonymous
    New Friend:
I have this same problem on one of my LG Vu's. New battery did not fix the problem. The charger is fine, because it works on my other Vu.
Posted on Feb 26, 2010
Anonymous
    New Friend:
I had the same problem too. It wasn't the battery or the charger. Ended up being a bad batter port. Had to get a new phone.
Posted on Apr 25, 2010
william
    New Friend:
  • 27 Answers
Either battery no good or the charger is no good
Posted on Feb 25, 2010
My lg Vu charges and says complete charge then when I use it I get 10 min talk on it and the charge is gone
You need to replace battery. Battery is going bad and not holding a full charge. Your phone will say full charge, because battery is fully charged to the capacity that it has left. Buy these on ebay, really cheap to buy them there.
Aug 17, 2010 | LG Vu CU920 Cellular Phone
Had my LG Vu CU920 phone about 18 months now, in past couple of weeks is started acting strange, could only talk about 1 to 2 min. and would get Battery Low signal, then lose connection. Same issue when...
Some of the 920's have had this issue and need to be exchanged out through the service provider. Most of the time they will swap out for free even over the 12 mo warranty for a technical issue like this. Prob have to speak with a manager.
Jul 11, 2010 | LG Vu CU920 Cellular Phone
The battery keeps dieing when uve talked for 3 mins even after fully charged
If you have used the phone for a while then probably the battery need to be replaced.
Feb 01, 2010 | LG Vu CU920 Cellular Phone
Battery is dying after 10 min talk time
Normally when a battery does that it has to do with it's very first charge. If the phone was turned on at all before the first charged reached it's full capacity, one day out of no where it will just die very quickly. You should also notice that when it charges it reaches a full charge more quickly than it did before. If that is not the case then you just got a defective battery. I can tell you for sure it doesn't have anything to do with the memory card.
Dec 28, 2009 | LG Dare VX9700 Cell Phone
The battery dies so fast
DramaQueen-
You charging port is probably going bad. It happens now and then.
Contact your provider if the phone is still under warranty.
If not check out the following link for solutions to the problem.
Problem With LG VU Not Charging
Jul 15, 2009 | LG Vu CU920 Cellular Phone
My Vu died last night. Got home and couldn't turn it on.
Return the phone to the dealer and they will probably give you a new one. The phone should be under warranty.
The phone may have a bad motherboard and just died. make sure your battery is the same model battery if not get the same model battery for his phone.
But i would just try and get a new one from your dealer.
Jun 04, 2009 | LG Vu CU920 Cellular Phone
Lg vu died....won't power on
maybe yes and no.try changing the batteries first.if not then a tech is the only option.
May 20, 2009 | LG Vu Cellular Phone
Phone dies completely when on standby for more than 20 minutes
You need to take the phone and have the firmware reflash
Dec 08, 2008 | LG Vu CU920 Cellular Phone
My LG Chocolate won't charge
seems like the battery is dead. just get a new battery
Oct 09, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG Vu CU920 Cellular Phone Logo
389 people viewed this question
Top LG Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Sheldon Dedek
William Alequin
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
