Question about Reddy Heater-170,000 BTU Kerosene Deluxe
When i plug in my unit it turns on for about 5 seconds and shuts off. doesnt ignite
Posted by chee6973 on
Anonymous
    New Friend:
  • 66 Answers
Check the fuel and tank. If it has been a while since fuel has been refilled, or it has sat without, you may have water in the tank.
Posted on Feb 22, 2010
Furnace comes on igniter comes on but gas dont
First shut off power to unit then check all wiring in control compartment. Look for any unhooked wires especially at gas valve and at control board. If no problem there then run unit and see if your gas valve is getting 24v at the terminal marked MV on the valve. Do this by putting one meter lead (red) on MV and one lead (black) on a good ground such as the metal of the cabinet itself. About 5 or ten seconds after the igniter begins to glow the board should send 24v to the valve. If it doesnt then the board thinks the igniter is not working or the board is bad. If there is 24v then the gas valve is bad but you can try giving the valve a few good raps with the handle of a screwdriver. This will sometimes free up the solinoid inside the valve but is only a temporary fix you will need a new valve. All this is assuming you have a hot surface igniter.
Sep 20, 2014 | Heating & Cooling
Not used for 2 years. It will not start.
Engine will
not start
1. Low on fuel or oil. 1. Add fuel or oil.
2. Ignition switch in "Off"position. 2. Turn to "ON" position
3. Faulty spark plug. 3. Replace spark plug.
4. Choke in wrong position. 4. Adjust choke accordingly.
5. Fuel shut-off valve in closed position 5. Open fuel shut-off valve.
6. Unit loaded during start-up. 6. Remove load from unit.
7. Spark plug wire loose. 7. Attach wire to spark plug.
Apr 23, 2011 | Porter Cable 5,500 Watt Portable Generator...
Pilot lights up but would not fire up into heating, I have brivis buffalo 85
This is the proper cycle of a furnace and what should happen.
Inducer motor kicks on, it runs for a little bit, about 3-5 seconds, then you should see a bright yellow glow, this is the igniter, shortly after, you should hear a click and the gas should start to flow, almost immediately it turns to a blue flame. Then your igniter should turn off and the blower motor start up.
If the pilot turns on and the gas ignites, then shortly after the unit shuts off, chances are this is your blower motor. It is not starting up, then the heat limit is reached in your unit and the safety shuts it off.
Mar 02, 2011 | Honeywell Programmable Thermostat Heater
Changed battery in key now it doesnt work 2004 mini built in 11/03
1.) Close all doors
2.) Switch the ignition switch to KL-R (first turn), switch back off within 5 seconds and remove the key
3.) Within 30 seconds, press and hold the unlock button and at the same time, press and release the lock button (3) times. (Must be completed within 10 seconds)
4.) Release both buttons. The doors will lock/unlock to signal a successful initialization.
5.) If additional keys need to be initialized, repeat steps 3-4 within 30 seconds
6.) Switching the ignition to KL-R completes the initialization
May 17, 2009 | 2003 Mini Cooper
Will not fire
this unit operates with a small air compressor at rear of motor. Remove the solid 1/8 inch plastic plug. install a low pressure gage. you should read around 5 psi
Feb 28, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Unit turns on for 5 seconds then shuts off.
I charged the unit and now it works fine. Plug into computer and charge for a while and the unit should work fine.
Mar 02, 2008 | Garmin StreetPilot c550 GPS Receiver
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Oct 21, 2007 | Holmes Products HM5080-U2 Humidifier
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
148 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
