Question about JVC KD-R200 Car CD/ MP3 Player
JVC stereo not working properly - 2001 Sonata
I hooked up a JVC stereo in my 2001 Sonata using a harness. When I connected the wires by color the radio would'nt come on. I tried different color combos and the only way the radio would play was when I crossed a yellow wire with the 2 red wires. Now the memory is wiped out for the radio + factory clock when I turn off the car. The radio will come back on, but no presets work. Any ideas what's wrong?
    New Friend:
  • 16 Answers
Generally wiring from the car is as follows...
red = ignition controlled live
yellow = permanent live
if you want stations saved and manual switch off of uni connect radio's yelow and red wires to the cars yellow.
if you want stations saved and radiounit switch off controlled by ignition (i.e only when car is running) then yellow to yellow and red to red. anything else will cause issues...
Posted on Feb 21, 2010
Testimonial: "Thanks, I now see what I did wrong."
    New Friend:
Want to know if there is a bulb replacement procedure for the heater dash controls on a 2000 v/w jetta ? thx
Posted on Feb 22, 2010
I have a 1995 saturn sl1. And i took out my factory radio and Will be putting in a JVC KW-AV50 stereo. My question is, how the hell to i wire the jvc up?
Get an aftermarket harness and dash kit for your car. Harness plugs into existing factory harness. Color coded for radio.
Nov 11, 2017 | JVC Car Audio & Video
16 point connecter radio wire harness on 03 Sonata what are the color codes for Brown white, gray ,brown black, grayblack.
2003 Hyundai Sonata Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Black/Yellow
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Red
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Black/White
Feb 03, 2017 | Cars & Trucks
Wiring problems with Kia stereo
The simple solution would be to go to the source where she bough the system
Dec 11, 2014 | 2001 Kia Spectra
Radio pro 4 wiring
You should purchase a radio harness for your car, and it's wires will connect to wires of the same color from your JVC radio harness. Join the two harnesses together (solder, crimp caps, barrel connectors, etc.) and then one end plugs into your JVC, the other end plugs into the factory harness that the original radio was connected to. If for some reason, your factory harness plug has been cut, you'll have to hardwire the JVC harness. I've included a link to the wiring diagram for your car. The steering wheel controls are moot; they will not work unless you've got some aftermarket adapter that allows them to interface with the JVC radio.
2004 pontiac grand prix speaker wiring diagram Google Search
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Nov 13, 2017 | Car Audio & Video
Do the jvs have a memory wire. I tryin to put this in a 2001 nissan altima. I need to know if the car have a memory wire for this redio.
You need to hook up the yellow wire from JVC to the yellow/green wire in car(12+ constant memory) and the red wire from JVC to purple from car(switched 12+ volt accessory)
Hope this gets you tuned in!
Oct 23, 2009 | JVC AM FM CD DET FACE CAR STEREO
How to remove 2001 hyndai sonata audio system
Instructions
Things You'll Need:
  • Screwdrivers
  • Wiring harness adaptor
  • Hyundai radio adaptor kit
  1. Open the coin holder and remove the two screws at the front. Pry the trim from around the gearshift lever and unhook the power wire to the cigarette lighter.
  2. Locate and remove the two screws from the bottom of the radio trim panel. Look for the screws, attached to a rod, below the glove box. Unhook the cable from the rod and pull the rod free.
  3. Place the shifter into "D" and slide the radio trim panel away from the dash. Locate the four screws at the front and sides of the stereo and remove them.
  4. Pull the stereo out of the Hyundai Sonata dash and disconnect the wires from the back of the unit. Connect the wiring harness adaptor to the original harness.
  5. Slide the new head unit into the Hyundai radio adaptor kit. Attach the wiring harness adaptor and antenna wire to the back of the new head unit and push the entire assembly into the dash.
  6. Secure the stereo in place with the four front and side screws and turn it on. Verify all of the speakers and features are working. Reattach the radio trim panel, insert the rod back into cable assembly and secure the trim around the gear shift.
In here you can find tips about remove radio...
- Hyundai Car Stereo removal
- Stereo Removal Hyundai (buy)
I really hope help you with this (remember rated this help). Good luck.
Oct 01, 2009 | 2001 Hyundai Sonata
1986 NISSAN 300Z THE STEREO WIRE WERE CUT NEED COLOR CODE PLEASE TRYING TO INSTALLED A FTER MARKET STEREO JVC
i have attached the wiring info you requested. be sure to test all wires with a meter before connecting. also a link to metra's website if you need an installation kit
http://www.metraonline.com/fitl.aspx
Battery RED/BLACK (+) RADIO HARNESS Accesory BLUE (+) RADIO HARNESS Ground N/A THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS. Illumination RED/YELLOW (+) RADIO HARNESS Dimmer N/A Power Antenna GREEN/BLACK (+) RADIO HARNESS LF Speaker (+) BLUE/WHITE LF Speaker (-) BLUE/YELLOW RF Speaker (+) BROWN RF Speaker (-) BROWN/WHITE LR Speaker (+) RED LR Speaker (-) GREEN RR Speaker (+) BLUE RR Speaker (-) PINK
Sep 02, 2009 | JVC AM FM CD DET FACE CAR STEREO
Color code for 01 acura integra factory stereo wiring harness
Battery BLUE/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) BLUE/GREEN
LF Speaker (-) GRAY/BLACK
RF Speaker (+) RED/GREEN
RF Speaker (-) BROWN/BLACK
LR Speaker (+) BLUE/YELLOW
LR Speaker (-) GRAY/WHITE
RR Speaker (+) RED/YELLOW
RR Speaker (-) BROWN/WHITE
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Dec 28, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Wiring my jvc kd-g331 to a 1996 vauxhall corsa
You can go to a place that installs car stereos and purchase a universal wiring harness for your car that will cost about $15 and allow you to do the wiring very easy without the need to know what every wire is for. This harness would be wired to the harness you got from JVC for your new radio and all you need to do is to match the colors of the JVC harness to the same colors of the universal harness that would then just plug right into the factory wiring harness for your car and then the other end plugs into the connector for your JVC radio. It is very easy and insures that you have all the proper wires connected to operate your radio and have full functions available for use.
If you require to know what each wire from the JVC harness is for, just ask.
I would be happy to offer you more help if you need it, just reply to this post and I will get back to you as soon as I am able.
If you found this free information to be useful a FixYa! rating would be appropiate and very much appreciated. After all, it is the only reward we get for helping people like yourself for free.
Thanks and good luck with your radio installation,
Dave
Sep 04, 2008 | JVC Car Audio & Video
JVC KD-R200 Car CD/ MP3 Player Logo
444 people viewed this question
Top JVC Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
