Question about Sewing Machines
I have a Necchi Royal Series 3205FA. I wanted to wind my bobbin. I could not loosen the Stop Clutch Knob. This is a NEW sewing machine. It isn't a strength problem. The part will not turn.
Posted by svp9 on
ken dourof
  • 980 Answers
If you have a stop motion dial with little grooves all the way round the best way is to get a wide plade screwdriver, put the plade part on one of the grooves on the left hand side of the dial and give it a thump on top with your hand, that usually does the trick.
Posted on Mar 07, 2010
Necchi heavy duty royal series. Manuel says 3205FA and 3204FB. I want to know where to oil it. I also need help because it won't reverse anymore. Any advice?
It's an old metal mechanical machine, right? It is probably seizing due to old oil that has dried. Here's my method for "unfreezing" old sewing machines. (You won't believe how good it sounds and how nicely it runs after you've give it some TLC!)
Wheel on right side that controls the needle up and down is very tight...
Jul 04, 2018 | Necchi Sewing Machines
How to thread a Necchi 3205 FA royal series
Search for:
Make Model threading
or
Make Model manual
https://www.sewingpartsonline.com/instruction-manual-necchi-3205fa-sewing-machine.aspx
Even if not your particular model, basic machine threading is very similar from one to another. Just be sure to ALWAYS RAISE the presser foot when threading the top thread---and change the needle often.
How do thread Necchi Royal Series Model 3205 sewing discussion topic...
How to Thread Necchi Sewing Machine
How to thread Necchi model 535 FA sewing machine now with captions
Nov 06, 2017 | Sewing Machines
I have a Necchi 3101FA. I am trying to figure out how to release the stop motion knob so that the needle won't run while I am trying to thread the bobbin. Does anyone have any idea?
the hand wheel is a 2 part device hold the outer wheel and release the inner part by turning it toward you . wen done winding bobbin retighten the wheels together .
Aug 26, 2015 | Necchi 3101 Mechanical Sewing Machine
Necchi 4825 bobbin winding problems
tell me exactly what you do when you want to rewind a bobbin. I got an old singer that will not sew but it makes a great bobbin winder for all the other machines .
May 12, 2015 | Necchi Sewing Machines
I have a Necchi 3205FA ROYAL series sewing machine. It will not sew at all the only time the needle moves is when I click the bobbin in and then it only moves for a second then stops completely.Should
Can you turn the handwheel manually? Does it move freely? If not, the machine needs to be oiled. Check the manual for the proper oiling locations. Basically, any metal to metal areas require oil. Just make sure the machine is unplugged and avoid oiling the motor.
Oct 13, 2014 | Sewing Machines
Ned a diagram (or detailed instructions) on to thread a Necchi 3205FA & installing the bobbin. Thanks.
try www.sewusa.com there are threading diagrams for some Necchi models. even if yours isnt there the bobbin should be similar.
Sep 20, 2011 | Necchi 3101 Mechanical Sewing Machine
I cannot loosen stop motion knob so that I can wind a bobbin.
Sometimes the knob locks so tight it requires a good strong beefy man to loosen it. Turn it counter clockwise!! You can also wind without loosening the knob, just MAKE SURE to unthread the machine and to sew for winding only. It works for all industrial machines, without loosening the knob.
Derek
Jan 15, 2011 | Brother Sewing Machines
I have inherited a Necchi 537FA. When I wind a bobbin I loosen the stop motion wheel, but the sewing mecfhanism doesn't disconnect, it still "sews" through the entire bobbin winding procedure! ...
Its been idle for too long and needs a good service. Try and trickle some oil behind the stop motion wheel. But what it actually needs is to have the wheel removed and then apply oil to the shaft. Careful when you start again as oil will fly out from the wheel so mind your drapes and wall decor.
Dec 12, 2010 | Necchi 3537 Mechanical Sewing Machine
The knob on wheel stuck.
Remove the needle, and place a screwdriver or something like it under the needle bar to keep the wheel from turning.
Wrap the knob in some type of fabric to keep it from being marred.
Using channel locks or water pump pliers, grasp the knob and turn it to the left. It should come loose. Once it is loosened, try it 2 or 3 times to make sure it works as it should.
Wind the bobbin, insert a new needle and have fun again.
sewman7
Dec 29, 2008 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
348 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
