Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
When you turn it on it will not work, it makes a humming noise but does not turn. Can't feel anything down in it to make it stick.
Posted by mp153044 on
Anonymous
    President:
  • 2,702 Answers
Dont go sticking your fingers down it,,, it could chop them off! and its likley to be the drive motor burnt out or some thing big and hard stuck inside it the humming is the motor trying to turn,, but it cant so its going to get very hot,,,have it looked at and dont keep turning it on till you do, it could catch fire
Posted on Feb 21, 2010
Ford expedition noise
humming could be the motor turning round but not engaging with the flywheel. you can check this by hitting the starter with a spanner a few times. if it starts up after you have a sticking solenoid. had to do this a few times my self to get engine started. replace starter as soon as possible if it works. usually happens if you not driven car for awhile.. or you do a lot of starting and small trips.
This is what my my brother-in-law says when riding with me. He knows more than I do. One of the shafts for my 2001 chevy 4X4 slips in and out. It makes a humming sound going down the street and makes
Does it make a noise when in 4x4 only? Does it make the noise in 2WD as well? A humming noise is usually associated with a wheel bearing noise. If while driving you steer from side to side and the noise changes pitch or becomes less/more severe it is most likely a wheel bearing. You can raise the vehicle and safely support it. Grab top and bottom of the wheel and feel for play.
2answers
BAD VIBRATION AND HUMMING NOISE AT 70KM/HR
Have the wheel bearings / wheel balance checked.
1helpful
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
3answers
Humming noise when turned on
The montherboard doesn't have anything that would make a humming noise. In all likelyhood it's the fan that sits on top of teh processor. It could be normal, but might need to be replaced or cleaned.
3answers
I have a '96 cavalier that makes a humming noise in the gas tank within 5 seconds of starting. I have tried two fuel pumps but the noise is still there!!!
Your fuel pump is supposed to hum, when you turn the key it primes the system and it will hum. When the car is running the fuel pump is running and it will hum. If the noise is excessive then try a higher quality fuel pump, it may be less noisy. You will hear the fuel pump on a lot of vehicles tho when you are sitting at a stop light with your radio off and everything quiet in the car.
7helpful
2answers
Everytime i use my frigidaire gas stove burner, it will make a loud humming noise. when i turn on a 2nd burner the humming sound will go away..is this normal for this brand?
SOUNDS LIKE YOU HAVE A REGULATOR PROBLEM. IT WONT HURT ANYTHING ITS JUST ANNOYING. OR YOU CAN REPLACE THE REGULATOR
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
3helpful
GE over the range micro JVM 1870 loud humming noise
When I read your post a shiver went down my spine... literally... You MUST be so careful working on/in Microwaves, you see they can be LETHAL...More service personnel, are killed each year servicing MW's, than any other, single piece of equipment. You see there is a BIG Capacitor inside This has enough energy, Joules, EVEN WHEN DISCONNECTED FROM THE MAINS. To KILL YOU. This must be discharged with a "Shorting Stick" BEFORE you touch anything else inside. Just touching anything connected to that Capacitor WILL SHOCK YOU. Obviously you haven't so please be careful. Anyway I have done my "Duty, and told you. What you do now, is up to you.
Loud humming noise
Stick you hand in the freezer, touch the back wall of freezer, see if you feel a strong or lite vibration equal to the hum you are hearing. If so, the you have a bad evap fan, if not then pull unit out from wall and see if hum is load toward the bottom rear portion of the frig, if so contact a repair tech.
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
Top Ace Hardware Electrical Supplies Experts
Mike
Michael Schaffter
Michael Schaffter
Level 1 Expert
durantheman
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
