The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
A flashing red light on a tall freezer indicates that the appliance has detected a temperature alarm, and the temperature inside the freezer has likely dropped below the desired range. A temperature of -6 degrees Celsius is much lower than the recommended temperature for a freezer (-18 degrees Celsius), which can cause frozen food to become damaged or spoiled.
To resolve the issue, you should first check the freezer's manual for troubleshooting tips and recommended actions. In general, you may need to adjust the thermostat to a higher temperature, remove any obstructions to airflow, or defrost the freezer if ice buildup is blocking the evaporator coils. If the issue persists, you should contact a qualified technician to diagnose and repair the freezer.
Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
? 3:50
https://www.youtube.com/watch?v=DFzTGKVo79g
Jun 27, 2010 - Uploaded by GE Appliances
CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
I understand that you are looking for the temperature control knob on your Frigidaire freezer, model# FFU2064DW. The temperature control is located inside your freezer on upright models, and on the left outside wall on chest models. The temperature is factory preset to provide satisfactory food storage temperatures. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. Hope this is helpful.
It seem ambient temperature will not affect so much inside temperature since any freezer has good insulation.
Normally freezer will go down to below zero degree
Is it getting cold at all. There may not be a problem. When you add a lot of food or clean the unit it is not unusual for the unit to require 24 hours to recover. You shoul use a thermometer to monitor the progress of the temperature recovery.
