Question about Montgomery Ward (223600UP) Heater
MW wall heater SFB-50145B, SN:HD47X, 50k BTU Unit functions fine, but pilot goes out intermitantly(3-7 days). Nat Gas, supply is good, pilot flame is 1.5" and blue. Thermostat is modern and works. just needs pilot relit constantly
Posted by dwitcraft on
Anonymous
    New Friend:
  • 66 Answers
Depending age of unit, clean either the thermocouple, or the flame sensor.
Posted on Feb 22, 2010
The pilot goes out when the heater cycles
The thermocouple is not working correctly. sometimes you can clean the soot build up from it and it will work again. sometimes they just need replacing. the thermocouple is what the pilot light flame heats up when you turn on the heater. when the thermocouple gets hot it sends a 20 to 60 millivolt signal to the gas valve to activate the gas flow to the main burner.
Feb 18, 2015 | Williams Wall Heaters: 50,000 BTU/Hr...
30,000 btu wall mount reddy heater nat. gas. pilot lights and heater will run for about a min. then i hear a click in the main control and everything shuts down. Is this the double safety i read about...
Yes your pilot light may not be surrounding the thermocouple. Check and see it the pilot is burning blue and surrounds the thermocouple . These units are very sensitive if even a little breeze across the unit. You can clean the pilot with compressed air or maybe even a small wire brush. If this doesn't work you may have to change the thermocouple.
Apr 21, 2011 | Heating & Cooling
Williams 3003622 Wall Mounted 30,000 BTU The pilot light goes out when the main flame shuts down. The pilot light will stay lit for days when heat is not called for but when heat is called for the furnace...
I'm having the same exact problem... At first we thought was the vent... but the way the flames goes out... it seems that there is "not enough oxygen" more than "blown out by the wind"... right after both main & pilot goes out, I can't even light any external flame inside the chamber... and it doesn't feel like the outside cold air coming in... it just feel like there is some sort of gas in the chamber that's so strong, it prevents flame... and the only thing I can think of is that it doesn't have enough oxygen, but too much natural gas, and flame can't sustain.
Nov 02, 2010 | Williams 3003622 Ceramic Wall Mounted...
Pilot light won't ignite.
One possible reason could be a bad thermocouple. This is a rod shaped device that is close to the flame. It's function is to turn off the gas if the pilot light goes out. Heat from the flame operates the thermocouple. When the flame goes out the thermocouple cools off and shuts off the gas. When one goes bad it will not let you light the pilot. Here's a picture of what one looks like. There's a bracket that holds it in place.f023fa6.jpg
May 02, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Charmglow ventless gas fireplace burners won't ignite
is pilot flame on the thermopile good, pilot flame should cover the thermocouple and thermopile if unit has both
Jan 07, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
I cant get the logs to light only the pilot light
Can you smell gas when the pilot goes out? If so, you may have too much pressure. If you just changed bottles and didn't do anything else, look at the flame sensor. It may be the problem. Good luck...Lee
Nov 12, 2009 | Blue Flame Charmglow 30K BTU Propane Vent...
Cozy heater 35000 btu pilot light goes out every 4 days
The thermocouple needs to get red hot. If the pilot flame is too low or too high or if it is not pointed on the thermocouple well, it won't stay hot enough. If the pilot flame is too low, a draft caused by opening a door could blow it out. If correcting this doesn't fix it, it could be a bad thermocouple or control. The factory assembly on these heaters is not the best.
Feb 02, 2009 | Cozy Enclosed Front Console Heater 70,000...
Pilot Light won't stay lit on wall furance
The low voltage wiring and the thermostat has noting to do with the pilot function of the wall furnace, check to see if when you have the pilot lit manually, while holding the button in does the flame impinge on the thermocouple and does the flame try to wrap around the thermocouple? if not the thermocouple and pilot flame need to be adjusted so that it impinges on the TC, if it does have a good flame impingment, then you probably have a bad TC from the factory, call them and have them send you a new one if still under warrenty.
Jan 20, 2009 | Williams 1403622 Gas Compact Heater
Williams wall heater
i'm having the same problems.......................
Oct 21, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Montgomery Ward (223600UP) Heater Logo
494 people viewed this question
Top Montgomery Ward Heating & Cooling Experts
Paul Carew
gbob59
Marvin
Marvin
Are you a Montgomery Ward Heating and Cooling Expert? Answer questions, earn points and help others
